Previous revision | |||
— | updating_firmware:updating_ve.bus_products [2023-06-29 10:48] (current) – [Notes] marianka | ||
+ | ====== Updating VE.Bus firmware, using VEFlash ====== | ||
+ | ===== VEFlash is deprecated in favour of VictronConnect ====== | ||
+ | Being both faster and easier to use, we now recommend to use VictronConnect for firmware updates. Instructions in the [[https:// | ||
+ | Use VEFlash only for (older) models not supported by VictronConnect. | ||
+ | Updating firmware on a VE.Bus product (Inverters, Multis and Quattros) has system-critical implications: | ||
+ | * All settings will be lost - [[https:// | ||
+ | * Assistants and parallel or three-phase configuration will be lost. | ||
+ | Setting up a VE.Bus system requires both training and experience. We offer no direct support for un-trained individuals carrying-out reconfiguration. | ||
+ | These instructions are for the VEFlash firmware update method, it is also possible to update [[https:// | ||
+ | ==== Notes ==== | ||
+ | * Updating a VE.bus product can be done using VEFlash.exe which you will find in VE Configure Tools, available for download on our [[https:// | ||
+ | * New firmware files are available from [[https:// | ||
+ | * To select the right file, check the firmware version which is in the product now. Look for a seven digit number (eg. 2654153) which you'll find printed on a sticker on the control board. The first four digits indicate the model, and must match the first four digits of the file you intend to upload. | ||
+ | * There are different firmware types available. Read our PDF [[https:// | ||
+ | * Always use the latest version of VEFlash. It will automatically check online for updates on startup | ||
+ | * When updating parallel or three-phase installation, | ||
+ | * After updating firmware, all settings will be reset to their factory defaults. The unit will be in stand-alone mode, and any // | ||
+ | * It is not required to keep your Victron equipment updated to the latest firmware version. Stable systems should be left with their current firmware. Firmware updates should only be done when it is recommended to fix an issue you are experiencing, | ||
+ | ==== Step by step instructions ==== | ||
+ | Follow the on screen steps. | ||
+ | Save the Firmware file in an easy to find folder. | ||
+ | Follow these steps carefully. | ||
+ | Once finished and OK is selected the Inverter/ | ||
+ | Note that all settings will be reset to defaults. Also that the unit will be reset to stand alone mode and any Assistant settings will be removed. | ||
+ | ~~DISQUS~~ |
