updating_firmware:updating_ve.bus_products [2018-03-20 10:53] – [Warning: This operation must only be carried out by Victron trained Engineers, Installers and Dealers, and must not be attempted by system owners and users.] justin_tyers_live_a_c | updating_firmware:updating_ve.bus_products [2023-06-29 10:48] (current) – [Notes] marianka | ||
- | ==== Warning: This operation must only be carried out by Victron-trained Engineers, Installers and Dealers, and must not be attempted by system Owners and Users. | + | ===== VEFlash is deprecated in favour of VictronConnect ====== |
- | Important! | + | Being both faster and easier to use, we now recommend to use VictronConnect for firmware updates. Instructions in the [[https:// |
- | * All settings will be lost. | + | |
+ | Use VEFlash only for (older) models not supported by VictronConnect. | ||
+ | Updating firmware on a VE.Bus product (Inverters, Multis and Quattros) has system-critical implications: | ||
+ | * All settings will be lost - [[https:// | ||
* Assistants and parallel or three-phase configuration will be lost. | * Assistants and parallel or three-phase configuration will be lost. | ||
- | Note. Reconfiguring | + | |
+ | Setting up a VE.Bus system requires both training and experience. We offer no direct support | ||
+ | These instructions are for the VEFlash firmware update method, it is also possible | ||
- | * To update | + | * Updating |
- | * New firmware files are available from [[https:// | + | * New firmware files are available from [[https:// |
* To select the right file, check the firmware version which is in the product now. Look for a seven digit number (eg. 2654153) which you'll find printed on a sticker on the control board. The first four digits indicate the model, and must match the first four digits of the file you intend to upload. | * To select the right file, check the firmware version which is in the product now. Look for a seven digit number (eg. 2654153) which you'll find printed on a sticker on the control board. The first four digits indicate the model, and must match the first four digits of the file you intend to upload. | ||
* There are different firmware types available. Read our PDF [[https:// | * There are different firmware types available. Read our PDF [[https:// | ||
Line 16: | Line 26: | ||
* After updating firmware, all settings will be reset to their factory defaults. The unit will be in stand-alone mode, and any // | * After updating firmware, all settings will be reset to their factory defaults. The unit will be in stand-alone mode, and any // | ||
- | + | * It is not required | |
- | Instruction video explaining how to update | + | |
- | {{youtube> | + | |
Line 56: | Line 64: | ||
- | ~~DISQUS~~ | ||
Line 66: | Line 73: | ||
+ | ~~DISQUS~~ |
updating_firmware/updating_ve.bus_products.1521539635.txt.gz · Last modified: 2018-03-20 10:53 by justin_tyers_live_a_c
