updating_firmware:updating_ve.bus_products [2016-06-08 23:14] – mvader | updating_firmware:updating_ve.bus_products [2023-06-29 10:48] (current) – [Notes] marianka | ||
- | ==== Warning: not for end-users | + | ===== VEFlash is deprecated in favour of VictronConnect ====== |
- | Important! Do not underestimate the complexity of updating firmware on a VE.Bus product (Inverters, Multis and Quattros). This document is intended for dealers and other Victron-trained installers and support-engineers. | + | |
- | During | + | Being both faster and easier to use, we now recommend to use VictronConnect for firmware updates. Instructions in the [[https:// |
+ | Use VEFlash only for (older) models not supported by VictronConnect. | ||
+ | Updating firmware on a VE.Bus product (Inverters, Multis and Quattros) has system-critical implications: | ||
+ | * All settings will be lost - [[https:// | ||
+ | * Assistants and parallel or three-phase configuration will be lost. | ||
+ | Setting up a VE.Bus system | ||
+ | These instructions are for the VEFlash firmware update method, it is also possible to update [[https:// | ||
- | * To update | + | * Updating |
- | * New firmware files are available from [[https:// | + | * New firmware files are available from [[https:// |
- | * To select the right file, look at the current | + | * To select the right file, check the firmware version |
- | * There are different firmware types available, read our PDF [[https:// | + | * There are different firmware types available. Read our PDF [[https:// |
* Always use the latest version of VEFlash. It will automatically check online for updates on startup | * Always use the latest version of VEFlash. It will automatically check online for updates on startup | ||
- | * After updating firmware, all settings will be reset to factory defaults. The unit will be reset to stand alone mode and any Assistant settings will be removed. | + | * After updating firmware, all settings will be reset to their factory defaults. The unit will be in stand-alone mode, and any //Assistant// settings will be removed. |
- | + | * It is not required | |
- | Instruction video explaining how to update | + | |
- | {{youtube> | + | |
Line 53: | Line 63: | ||
- | ~~DISQUS~~ | ||
Line 65: | Line 73: | ||
+ | ~~DISQUS~~ |
updating_firmware/updating_ve.bus_products.1465420470.txt.gz · Last modified: 2016-06-08 23:14 by mvader
