system_integration:hub4_grid_parallel
system_integration:hub4_grid_parallel [2016-08-16 13:33] – [Sustain Mode] mvader | system_integration:hub4_grid_parallel [2019-01-22 10:16] (current) – external edit 127.0.0.1 | ||
- | ====== Hub-4 / grid parallel - manual ====== | + | ====== Hub-4 / grid parallel - manual |
+ | Do not use Hub-4 for new installs. It is deprecated in favor of [[ess: | ||
+ | ===== OLD MANUAL ===== | ||
+ | ===== 1. Introduction & features | ||
Note: make sure to always update all components to the latest software when making a new installation. | Note: make sure to always update all components to the latest software when making a new installation. | ||
=== Introduction === | === Introduction === | ||
- | Hub-4 is a Grid-parallel Energy Storage system, using the Multi or Quattro bidirectional inverter/ | + | Hub-4 is a Grid-parallel Energy Storage system, using the Multi or Quattro bidirectional inverter/ |
- | The system is managed by the [[https:// | + | The system is managed by the [[https:// |
=== Schematic overview === | === Schematic overview === | ||
=== Features === | === Features === | ||
* Grid parallel energy storage system that optimizes self consumption. | * Grid parallel energy storage system that optimizes self consumption. | ||
* Wide range of available inverter/ | * Wide range of available inverter/ | ||
- | * Flexible: | + | * Single, split- or three-phase: |
- a single phase inverter/ | - a single phase inverter/ | ||
- a split- or three-phase inverter/ | - a split- or three-phase inverter/ | ||
+ | * Flexible PV type: use AC-Coupled PV in parallel to the Multi, AC-Coupled PV on the output of the Multi, DC-Coupled PV, or a combination of those three | ||
* Both wired and a wireless connection to the meter central distribution box is possible. | * Both wired and a wireless connection to the meter central distribution box is possible. | ||
* (optional) No-break UPS output. | * (optional) No-break UPS output. | ||
* (optional) Phase compensation. | * (optional) Phase compensation. | ||
* Built-in anti-islanding / loss of mains detection. Currently certified for limited number of countries/ | * Built-in anti-islanding / loss of mains detection. Currently certified for limited number of countries/ | ||
- | * No restrictions on PV Array size. | + | * No restrictions on installed |
* No minimum or maximum battery size. | * No minimum or maximum battery size. | ||
* Suitable for many battery types. | * Suitable for many battery types. | ||
* Three operating modes, from basic to custom, covering both standard and custom systems. | * Three operating modes, from basic to custom, covering both standard and custom systems. | ||
* Free usage of the [[https:// | * Free usage of the [[https:// | ||
- | * Winter switch: keep batteries charged in periods where there is a continuous shortage of solar power | + | * BatteryLife: extend battery life time, and also be prepared for a grid outage |
=== Operating modes === | === Operating modes === | ||
Line 35: | Line 41: | ||
- Advanced \\ Same as standard, but more flexibility is given to implement time shifting, load management or other energy management optimization algorithms. Either by ModbusTCP commands or by running additional self implemented code on the Color Control GX. Often the best of both worlds: complete flexibility and benefit from the VRM Portal and all other functionality already available on the CCGX, without having to add additional cost of extra PLCs or other control modules. [[system_integration: | - Advanced \\ Same as standard, but more flexibility is given to implement time shifting, load management or other energy management optimization algorithms. Either by ModbusTCP commands or by running additional self implemented code on the Color Control GX. Often the best of both worlds: complete flexibility and benefit from the VRM Portal and all other functionality already available on the CCGX, without having to add additional cost of extra PLCs or other control modules. [[system_integration: | ||
- Custom \\ Customer self implements their control loop and grid measurements, | - Custom \\ Customer self implements their control loop and grid measurements, | ||
- | ===== 1. Required parts ===== | + | ===== 2. Required parts ===== |
^ Part no. ^ Description | ^ Part no. ^ Description | ||
| PMP, CMP or QUA | Multi or Quattro inverter/ | | PMP, CMP or QUA | Multi or Quattro inverter/ | ||
- | | REL200100000 | + | | REL200100000 |
| BPP000300100R | Color Control GX | | | BPP000300100R | Color Control GX | | ||
| ASS03006xxxx | | ASS03006xxxx | ||
Line 60: | Line 66: | ||
Notes: | Notes: | ||
- The Multi or Quattro used needs to be a recent type with the new microprocessor (26xxxxx or 27xxxxx). All units currently shipping have this new microprocessor. Also, the Multi or Quattro needs to run the latest 4xx firmware. Contact your Victron representative for the firmware files. Update instructions are [[updating_firmware: | - The Multi or Quattro used needs to be a recent type with the new microprocessor (26xxxxx or 27xxxxx). All units currently shipping have this new microprocessor. Also, the Multi or Quattro needs to run the latest 4xx firmware. Contact your Victron representative for the firmware files. Update instructions are [[updating_firmware: | ||
- | - The RS485 to USB interface cable from the CCGX to the AC sensor can be extended up to 100 meters max. | + | |
- | - The REL200100000 is the EM24DINAV93XISX from Carlo Gavazzi. Other EM24 models from Carlo Gavazzi can also be used, as the communication is the same. For example the EM24DINAV53DISX, | + | ===== 3. Battery, inverter/ |
- | ===== 2. Battery, inverter/ | + | |
=== Battery size === | === Battery size === | ||
Line 80: | Line 85: | ||
Note that even in an Hub-4 installation, | Note that even in an Hub-4 installation, | ||
- | ===== 3. Single vs multi phase installations ===== | + | ===== 4. Single vs multi phase installations ===== |
- | ==== 3.1 Single phase inverter/ | + | ==== 4.1 Single phase inverter/ |
=== Phase compensation === | === Phase compensation === | ||
Phase compensation, | Phase compensation, | ||
Line 96: | Line 101: | ||
Enabling or disabling phase compensation is done in the Hub-4 settings on the Color Control GX. See the screenshot further down below in this manual. | Enabling or disabling phase compensation is done in the Hub-4 settings on the Color Control GX. See the screenshot further down below in this manual. | ||
- | ==== 3.2 Split- and three-phase inverter/ | + | ==== 4.2 Split- and three-phase inverter/ |
=== Installation details === | === Installation details === | ||
Line 121: | Line 126: | ||
In a multi-phase system, the charge current is configured per phase. There is not a total charge current which the system adheres too. This means that, for example when there is a relatively small battery bank, and a huge over production of PV on L1, and not on the other phases, only part of that over production on L1 will be used to charge the battery. | In a multi-phase system, the charge current is configured per phase. There is not a total charge current which the system adheres too. This means that, for example when there is a relatively small battery bank, and a huge over production of PV on L1, and not on the other phases, only part of that over production on L1 will be used to charge the battery. | ||
- | ===== 4. Connecting and configuring the AC sensor | + | ===== 5. Grid Meter ===== |
- | A Hub-4 setup requires an AC sensor connected in the main distribution panel: between the grid and installation. This AC sensor has been designed for 3 phase measurement, | + | |
- | === 3-phase setup diagram: === | + | A Hub-4 setup requires an Energy Meter connected in the main distribution panel: between the grid and installation. The meter is a three phase meter, but can be used for single phase installations as well. |
- | === single phase setup diagram: === | + | Follow the instructions in the [[:energy-meter|Energy Meter manual]]. |
- | Note the jumper between terminals 1 and 4. You do not need this connection if you have the version AV2 of the sensor. | + | ===== 6. Multi/ |
- | === Meter configuration | + | |
- | Change the front selector of the AC sensor so it is not in the locked state. This will allow the CCGX to automatically configure the meter. The front selector is located next to the display as indicated in the image below. | + | |
- | === Option A: Wireless connection to CCGX === | + | |
- | 1. Connect the Zigbee to USB converter to the CCGX using the supplied USB cable. A few seconds after connecting, the active LED should be on and the TX/RX LED should be blinking (the converter takes its power from the CCGX, so the CCGX needs to be switched on as well). | + | |
- | 2. Connect the Zigbee to RS485 converter to the EM24 energy meter: | + | |
- | ^ Converter ^ Grid meter ^ | + | |
- | | GND | Terminal 43 | | + | |
- | | A | Terminal 42 | | + | |
- | | B | Terminal 41 | | + | |
- | 3. Make sure only one Zigbee device is powered up right now: the Zigbee to USB converter connected to the CCGX. Power down all others. //If you don't do this, the Zigbee to RS485 converter may be connected permanently to another Zigbee device.// | + | |
- | 4. Connect the 12V DC power supply to the Zigbee to RS485 converter. When the power is switched on, check the LEDs again. | + | |
- | === Option B: Wired connection to CCGX === | + | |
- | Connect the meter to the CCGX using the USB to RS485 converter cable: | + | |
- | ^ RS485 Converter ^ Grid meter ^ | + | |
- | | Yellow | + | |
- | | Orange | + | |
- | | Black | Terminal 43 | | + | |
- | The Red, Green and Brown wire are not used | + | |
- | ===== 5. Multi/ | + | |
Follow the instructions as per the standard installation manual that comes with the inverter/ | Follow the instructions as per the standard installation manual that comes with the inverter/ | ||
Line 176: | Line 141: | ||
* (option) Connect MPPT Solar chargers to the DC side of the system. In this case make sure to either use a battery with built-in SOC, like an LG or BMZ battery, or add a BMV Battery monitor. And select that battery or battery monitor as the System Battery Monitor in the Settings -> System Setup Menu. Also keep the Sync SOC to VE.Bus option, a setting in that same menu, enabled. | * (option) Connect MPPT Solar chargers to the DC side of the system. In this case make sure to either use a battery with built-in SOC, like an LG or BMZ battery, or add a BMV Battery monitor. And select that battery or battery monitor as the System Battery Monitor in the Settings -> System Setup Menu. Also keep the Sync SOC to VE.Bus option, a setting in that same menu, enabled. | ||
- | ===== 6. Multi/ | + | ===== 7. Multi/ |
Steps: | Steps: | ||
- Update the devices to the latest firmware version. Instructions [[updating_firmware: | - Update the devices to the latest firmware version. Instructions [[updating_firmware: | ||
- | - Use VEConfigure3 to [[assistants: | + | - Use VEConfigure3 to add the self-consumption Hub-4 Assistant. Instructions on how to add an Assistant |
+ | Notes with regards to the Input current limit and PowerAssist: | ||
+ | * The Hub-4 Assistant will disable the PowerAssist setting in VEConfigure3. Please keep this option disabled. Note that the Hub-4 system will still PowerAssist, | ||
+ | * Input current limiter setting will work. The configured limit is used as the threshold for AC current at the ACin of the Multi/ | ||
+ | * Do **not** enable the Dynamic current limiter setting in VEConfigure3 | ||
* Whenever there is more PV power available than necessary to power the loads, the battery will be charged. Charge current and other parameters are configured on the Charger tab in VEConfigure3. | * Whenever there is more PV power available than necessary to power the loads, the battery will be charged. Charge current and other parameters are configured on the Charger tab in VEConfigure3. | ||
- | * The Hub-4 Assistant will disable PowerAssist. Please keep this option disabled. | ||
* Make sure to keep the lithium batteries checkbox on the charger page consistent with the battery choice in the Assistant. | * Make sure to keep the lithium batteries checkbox on the charger page consistent with the battery choice in the Assistant. | ||
* If you have a Multi Compact, check the DIP switches: DIP switch 1 must be on, and DIP switch 2 must be off. | * If you have a Multi Compact, check the DIP switches: DIP switch 1 must be on, and DIP switch 2 must be off. | ||
- | ===== 7. Controlling depth of discharge ===== | + | ===== 8. Controlling depth of discharge ===== |
//(Note: All absolute voltages mentioned in the text below are for a 12V system and should be multiplied by 2 or 4 for a 24V or 48V system.)// | //(Note: All absolute voltages mentioned in the text below are for a 12V system and should be multiplied by 2 or 4 for a 24V or 48V system.)// | ||
- | When there is less PV power available than needed by the loads (a PV shortage, at night for example), energy stored in the battery will be used to power the loads. This continuous | + | When there is less PV power available than needed by the loads (a PV shortage, at night for example), energy stored in the battery will be used to power the loads. This continues |
- | - Battery State of Charge. Minimum | + | - Battery State of Charge: Minimum |
- | - Battery Voltage. See [[# | + | - Battery Voltage. See [[# |
- | - Low cell signal from BMS | + | - Low cell signal from a BMS: |
+ | * Victron VE.Bus BMS | ||
+ | * 3rd party Canbus enabled | ||
- | The Sustain mode will be activated automatically __after__ the battery has been flagged as empty. See Sustain section below for more information. | + | __What about the Sustain mode?__ |
- | Notes: | + | The Sustain voltages do not effect when the system stops discharging the battery: Sustain |
- | * the Minimum SOC threshold is only active while mains is connected. | + | |
- | * it is also possible to set the minimum state of charge in the Hub-4 Assistant itself, but this is not recommended and we'll remove that option in the near future. Use the same setting in the Color Control GX instead. | + | |
- | ==== Sustain Mode ==== | + | __What happens during a mains outage?__ |
- | The purpose | + | * Minimum Battery State of Charge |
+ | * Dynamic cut-off is still active | ||
+ | * Low cell signal from the VE.Bus BMS is still active | ||
+ | * Low cell signals from 3rd party canbus enabled BMS-es are ignored. System relies on the protection inside such a Lithium | ||
- | During Sustain Mode, the batteries will slowly be charged from the grid; maximum | + | __Configuring minimum state of charge |
- | Excess solar power will also be used to charge the batteries. Sustain stops as soon as there has been sufficient excess solar power available to raise the battery voltage 0.1 V above the sustain level. Normal operation will then continue: solar deficits are complemented with power from the battery again. | + | It is possible |
==== Dynamic Cut-off ==== | ==== Dynamic Cut-off ==== | ||
Line 220: | Line 192: | ||
* The Dynamic cut-off mechanism is in effect both when mains is available, and during a mains failure (system is in Inverter mode) | * The Dynamic cut-off mechanism is in effect both when mains is available, and during a mains failure (system is in Inverter mode) | ||
+ | ==== Sustain Mode ==== | ||
+ | The purpose of the Sustain Mode is to prevent battery damage caused by leaving batteries in a deeply discharged state. The Sustain Mode is entered after the battery has been discharged, see above. | ||
+ | During Sustain Mode, the batteries will slowly be charged from the grid; maximum charge current is 5 Ampére. The Sustain level is 12.5V for lithium batteries. For non-lithium batteries, the sustain level is 11.5 V for the first 24 hours, and after that it is raised to 12.5 V. | ||
+ | Excess solar power will also be used to charge the batteries. Sustain stops as soon as there has been sufficient excess solar power available to raise the battery voltage 0.1 V above the sustain level. Normal operation will then continue: solar deficits are complemented with power from the battery again. | ||
- | ===== 8. Color Control GX configuration ===== | + | ===== 9. Color Control GX configuration ===== |
- Power up the system. | - Power up the system. | ||
- After a few seconds, the display will come to life. If not, check the wiring of the system. | - After a few seconds, the display will come to life. If not, check the wiring of the system. | ||
Line 230: | Line 208: | ||
==== BatteryLife ==== | ==== BatteryLife ==== | ||
- | The battery life feature prevents low battery state of charge over a long period. This may happen when there is insufficient PV power available to recharge the battery every day, for example in winter. | ||
- | BatteryLife | + | === What does it do? === |
+ | In case the expected Solar energy reduces, because of less sun shine, the system | ||
+ | In case the expected Solar energy increased, because of more sun shine, the system will automatically decrease its low SOC limit. So that, with this increased expected Solar Energy, the battery will still be fully charged at the end of the day to approx 100%. | ||
+ | Ask yourself, "Why should the battery be fully discharged, and stay that way? With as a result no reserve power in case of mains failure, and possible also a damaged battery" | ||
+ | === Details === | ||
+ | The BatteryLife feature prevents low battery state of charge over a long period. For example in winter, when there is insufficient PV power available to recharge the battery every day. | ||
+ | BatteryLife ensures | ||
+ | It has several advantages: | ||
+ | * Operating in a partial state of charge is bad for lead acid battery life | ||
+ | * Certain lithium batteries need to be fully charged regularly, in order to balance. This includes the [[https:// | ||
+ | * In case of mains failure, it is best to have spare energy available to power the loads from the battery. Continuously operating in a low state of charge serves no purpose. | ||
To do this we introduce a dynamic lower limit on the state of charge. Discharging is allowed only if the state of charge exceeds the limit. The limit is adjusted every day. On days with little or no surplus PV power the limit will be raised. And on ' | To do this we introduce a dynamic lower limit on the state of charge. Discharging is allowed only if the state of charge exceeds the limit. The limit is adjusted every day. On days with little or no surplus PV power the limit will be raised. And on ' | ||
Line 239: | Line 233: | ||
This graphs shows a system in the spring, battery state of charge graphed over time. During the week progressing, | This graphs shows a system in the spring, battery state of charge graphed over time. During the week progressing, | ||
==== BatteryLife configuration ==== | ==== BatteryLife configuration ==== | ||
- | * Actual state of charge limit:\\ The dynamic state of charge limit. Battery discharge will be disabled when the SoC reached this level. Hub-4 assistant settings (SoC stop level and dynamic cut-off) take priority to this limit. So discharge may be stopped before the limit is reached (sustain mode). The SoC stop level can be disabled safely when battery life is enabled. | + | * Actual state of charge limit:\\ The dynamic state of charge limit. Battery discharge will be disabled when the SoC reached this level. Hub-4 assistant settings (SoC stop level and dynamic cut-off) take priority to this limit. So discharge may be stopped before the limit is reached (sustain mode). The SoC stop level can be disabled safely when BatteryLife |
* Minimum state of charge limit:\\ The actual state of charge limit (and therefore the state of charge itself) will never be lowered below this limit. | * Minimum state of charge limit:\\ The actual state of charge limit (and therefore the state of charge itself) will never be lowered below this limit. | ||
- | * The different | + | * The different |
* Self consumption: | * Self consumption: | ||
* Discharge disabled: the battery has been discharged to the actual SoC limit. The state will return to //self consumption// | * Discharge disabled: the battery has been discharged to the actual SoC limit. The state will return to //self consumption// | ||
Line 252: | Line 248: | ||
For further configuration of the Color Control GX, see its [[ccgx: | For further configuration of the Color Control GX, see its [[ccgx: | ||
- | ===== 9. Using the Wired HUB-4 AC Sensor to measure PV Inverter output ===== | ||
- | Instead of used for the Hub-4 regulation, the same three phase meter can be configured to measure output of a PV Inverter. Make sure to check Paragraph 1.3 in the [[ccgx: | ||
- | Installation is similar to the AC sensor on the grid. Terminals 1, 4 and 7 should face the PV inverter. On the CCGX change the ' | + | ===== 11. Troubleshooting ===== |
- | There are 3 options to connect the extra AC sensor: | + | === The system |
- | - Wired connection with an extra RS485 to USB converter cable. Works just like the grid meter. | + | |
- | - Wired connection with modbus multidrop (both AC sensors connected to the same RS485 to USB converter cable). In this case you need to change the modbus address of one of the AC sensors (see below). | + | |
- | - Wireless connection: the AC sensor | + | |
- | Changing the modbus address: | + | |
- | | + | - Is State of Charge at or below the [[# |
- | - Press the joystick down again and release immediately. | + | - Is the system in [[# |
- | - Press the joystick right several times until ' | + | |
- | - Press down again. ' | + | |
- | - Press down again twice. ' | + | |
- | - Press right until ' | + | |
- | - Press down. The display now shows measurements again. | + | |
- | On a single phase setup, you can use a single AC sensor to measure both grid and PV inverter. For wiring see the diagram below. | + | === The system is not charging === |
- | On the CCGX go to the grid meter in the Wired AC sensor settings. Make sure 'Phase type' is set to ' | + | === The system is in passthrough, |
- | {{: | + | Check the connection between the AC Sensor and the CCGX. |
- | ===== 10. FAQ ===== | + | ===== 12. FAQ ===== |
=== What happens when the Multi does not receive data from the CCGX / Wired AC Sensor? === | === What happens when the Multi does not receive data from the CCGX / Wired AC Sensor? === | ||
It will switch to Bypass, and Sustain mode is still active and will prevent the battery from being discharged below, approximately, | It will switch to Bypass, and Sustain mode is still active and will prevent the battery from being discharged below, approximately, | ||
=== Is there a winter mode, like in Hub-2? === | === Is there a winter mode, like in Hub-2? === | ||
- | Yes. | + | No, but there is BatteryLife. |
=== VEConfigure keeps giving the warning ' | === VEConfigure keeps giving the warning ' | ||
Line 313: | Line 300: | ||
* The solar power coming through the solar chargers will be used to charge the battery and to power the AC loads. Both AC loads connected in parallel to the inverter/ | * The solar power coming through the solar chargers will be used to charge the battery and to power the AC loads. Both AC loads connected in parallel to the inverter/ | ||
* Powering AC loads will have priority over battery charging when state of charge is above the configured minimum state of charge. And, reversely, charging the battery will have priority when the state of charge is below the configured minimum. | * Powering AC loads will have priority over battery charging when state of charge is above the configured minimum state of charge. And, reversely, charging the battery will have priority when the state of charge is below the configured minimum. | ||
- | * Solar power coming from the MPPT solar chargers will not be fed back into the grid. | + | * Solar power coming from the MPPT solar chargers will not be fed back into the grid. |
+ | * Both Solar Charge Controllers with a VE.Can communication port as well as with a VE.Direct communication port can be used. | ||
+ | * There is no VE.Bus to VE.Can interface cable required, also it is not required to set absorption and float voltages in the mppt higher than the same in the Multi or Quattro. | ||
system_integration/hub4_grid_parallel.1471347237.txt.gz · Last modified: 2016-08-16 13:33 by mvader
