system_integration:hub4_grid_parallel-ccgx_control_loop
system_integration:hub4_grid_parallel-ccgx_control_loop [2015-10-29 16:30] – [8. Using the Wired HUB-4 AC Sensor to measure PV Inverter output] edevries | system_integration:hub4_grid_parallel-ccgx_control_loop [2015-11-05 15:13] – [9. FAQ] mvader | ||
Line 215: | Line 215: | ||
=== Is there a winter mode, like in Hub-2? === | === Is there a winter mode, like in Hub-2? === | ||
- | No not yet. | + | Yes, this is coming in CCGX v1.30 |
+ | === VEConfigure keeps giving the warning ' | ||
+ | This message is a bug. There is no need to reset the device. The mechanism that erroneously triggers that message will be removed in a future VE.Bus firmware version. | ||
~~DISQUS~~ | ~~DISQUS~~ |
system_integration/hub4_grid_parallel-ccgx_control_loop.txt · Last modified: 2019-01-22 10:41 by 127.0.0.1
