system_check
Last revisionBoth sides next revision | |||
system_check [2018-11-19 16:13] – created guy_stewart | system_check [2018-11-19 16:17] – guy_stewart | ||
Line 44: | Line 44: | ||
Loose wires are a common source of faults. If you feel a wire might be loose, or has some wiggle - or obviously if it comes free entirely - you will need to secure it properly. In this case it’s best to shut the system down. Loose wires can lead to electrical arcing or sparks. And exposed wires may have the potential to give you an electric shock. | Loose wires are a common source of faults. If you feel a wire might be loose, or has some wiggle - or obviously if it comes free entirely - you will need to secure it properly. In this case it’s best to shut the system down. Loose wires can lead to electrical arcing or sparks. And exposed wires may have the potential to give you an electric shock. | ||
- | The safe way to shutdown a system is to first begin at the termini | + | The safe way to shutdown a system is to first begin at the loads and work toward the batteries: |
* Turn off all loads at their switches. | * Turn off all loads at their switches. | ||
Line 54: | Line 54: | ||
If a wire does come loose, inspect it closely: Does it have damage to the copper strands? If so, use some pliers to remove the damage, peeling back some of the insulation. | If a wire does come loose, inspect it closely: Does it have damage to the copper strands? If so, use some pliers to remove the damage, peeling back some of the insulation. | ||
- | Wherever there are plugs and sockets, or lugs and bolts, check their connections. We want to make sure that all connections are good. | + | Wherever there are plugs and sockets, or lugs and bolts, check their connections. We want to make sure that all connections are good and without any corrosion. |
==== Firmware ==== | ==== Firmware ==== | ||
- | Before asking a question on an existing installation, | + | Before asking a question on an existing installation, |
[[https:// | [[https:// |
system_check.txt · Last modified: 2019-01-22 10:43 by 127.0.0.1
