start [2021-06-01 09:56] dirktebiestart [2023-05-06 02:21] (current) – [Want to help improving documentation?] guy_stewart
-hello, +===== Documentation =====
-i'm owner of a MultPlus 48/1600/20 and i use it to charge my DIY LiFePo4 power-storage. +
-now i control its function by switching it On and Off with the "remote"-contact by a RaspberryPi. +
-The RaspberryPi read the Input and Overload of my SMA-EnergyMeter and then switch the charging on, if there is more power, than i need in my house. +
-but i find out, that i can change the charging current with Ve-Configure(windows) while the charger is loading the batteries. +
-so i think it may be a useful function, to change the charging current depending on the overload of the PV-Equipment. +
-I read the Documents about the protocol to talk over the MK3-adaptor, but i can't find the solution, how to set the parameter. +
-All the other open-source projects are made only to read and document the use of the parts. +
-i need such a sequence, which code i have to transfer to the MK3(FTDI), so i can set the parameter for charging current. +
-my main program is running in python(3) on the RaspberryPi. +
-thanks for help +
- ===== Documentation =====+
 ==== Looking for product documentation and manuals? ==== ==== Looking for product documentation and manuals? ====
Line 31: Line 14:
 ==== Want to help improving documentation? ==== ==== Want to help improving documentation? ====
-By creating an account at the top right, you can change this documentation yourselfPlease don't hesitate to fix small typos yourselfBut also bigger changes are much appreciated. We'll receive an email of every change, and can always revert back to a previous version. Read [[:introduction|the introduction]] for some tips and tricks, for example how to receive email updates about new content if you want to stay up to date with changes.+
 +If you see issues or improvements that could be made to any Victron documentation, please let us know by creating a new post with the suggested changes (or question if something requires clarification) via [[https://community.victronenergy.com/index.html|Victron Community]].
 +If you want to stay up to date on changes that are made to Victron documentation, become a member of the  [[https://professional.victronenergy.com|Victron Professional portal]], and subscribe to the email newsletter.
 +In addition, you can also stay up to date with changes to the specific documentation that uses this live site (such as our [[battery_compatibility:|battery compatibility list]]) by creating an account at the top right. Read this [[:introduction|the introduction]] for how to set this up.
start.1622534161.txt.gz · Last modified: by dirktebie
