start [2021-06-01 09:56] – dirktebie | start [2021-06-01 10:22] – mvader | ||
- | hello, | + | ===== Documentation ===== |
- | i'm owner of a MultPlus 48/1600/20 and i use it to charge my DIY LiFePo4 power-storage. | + | |
- | now i control its function by switching it On and Off with the " | + | |
- | The RaspberryPi read the Input and Overload of my SMA-EnergyMeter and then switch the charging on, if there is more power, than i need in my house. | + | |
- | but i find out, that i can change the charging current with Ve-Configure(windows) while the charger is loading the batteries. | + | |
- | so i think it may be a useful function, to change the charging current depending on the overload of the PV-Equipment. | + | |
- | I read the Documents about the protocol to talk over the MK3-adaptor, | + | |
- | All the other open-source projects are made only to read and document the use of the parts. | + | |
- | i need such a sequence, which code i have to transfer to the MK3(FTDI), so i can set the parameter for charging current. | + | |
- | my main program is running in python(3) on the RaspberryPi. | + | |
- | thanks for help | + | |
- | ===== Documentation ===== | + | |
==== Looking for product documentation and manuals? ==== | ==== Looking for product documentation and manuals? ==== |
