start [2018-11-11 14:10] – [Asking questions] mvader | start [2021-06-01 09:56] – dirktebie | ||
- | ===== Welcome to Victron Live ===== | + | hello, |
- | ==== Looking for product documentation and manuals? ==== | + | i'm owner of a MultPlus 48/1600/20 and i use it to charge my DIY LiFePo4 power-storage. |
- | Find your product [[https://www.victronenergy.com/ | + | now i control its function by switching it On and Off with the " |
+ | The RaspberryPi read the Input and Overload of my SMA-EnergyMeter | ||
+ | but i find out, that i can change the charging current with Ve-Configure(windows) while the charger is loading the batteries. | ||
+ | so i think it may be a useful function, to change the charging current depending on the overload of the PV-Equipment. | ||
+ | I read the Documents about the protocol to talk over the MK3-adaptor, | ||
+ | All the other open-source projects are made only to read and document the use of the parts. | ||
+ | i need such a sequence, which code i have to transfer to the MK3(FTDI), so i can set the parameter for charging current. | ||
+ | my main program is running in python(3) on the RaspberryPi. | ||
- | ==== Want to help improving documentation? | + | thanks for help |
- | By creating an account at the top right, you can change this documentation yourself. Please don't hesitate to fix small typos yourself. But also bigger changes are much appreciated. We'll receive an email of every change, and can always revert back to a previous version. Read [[: | + | |
- | ==== Documents that still need to made available from main website ==== | + | |
- | DC-Coupled PV | + | |
- | Multi or Quattro combined with one or more solar chargers. | + | |
- | Other: | + | |
- | * [[battery_balancer_demo_webapp|Battery balancer demo webapp]] | + | |
- | * [[ac_current_sensor: | + | |
- | * [[eco_multi: | + | |
+ | ===== Documentation ===== | ||
+ | ==== Looking for product documentation and manuals? ==== | ||
+ | Find your product [[https:// | ||
+ | You can also search for your [[https:// | ||
==== Support ==== | ==== Support ==== | ||
Line 33: | Line 27: | ||
All support enquires should follow the directions here - https:// | All support enquires should follow the directions here - https:// | ||
- | We also have a new platform called | + | Looking for Disqus? That has been replaced by Victron Community: https:// |
- | https:// | + | |
- | Please use the new system for your questions, as well as for helping other people. The topic feature can help with specific issues. | ||
- | Looking forward to see you there. | ||
- | ~~DISQUS~~ | ||
+ | ==== Want to help improving documentation? | ||
+ | By creating an account at the top right, you can change this documentation yourself. Please don't hesitate to fix small typos yourself. But also bigger changes are much appreciated. We'll receive an email of every change, and can always revert back to a previous version. Read [[: |
