start [2018-05-22 13:31] – old revision restored (2018-01-13 08:26) mvader | start [2021-06-01 09:56] – dirktebie | ||
- | ===== Welcome to Victron Live ===== | + | hello, |
- | ==== Looking for product documentation and manuals? ==== | + | i'm owner of a MultPlus 48/1600/20 and i use it to charge my DIY LiFePo4 power-storage. |
- | Find your product [[https://www.victronenergy.com/ | + | now i control its function by switching it On and Off with the " |
+ | The RaspberryPi read the Input and Overload of my SMA-EnergyMeter | ||
+ | but i find out, that i can change the charging current with Ve-Configure(windows) while the charger is loading the batteries. | ||
+ | so i think it may be a useful function, to change the charging current depending on the overload of the PV-Equipment. | ||
+ | I read the Documents about the protocol to talk over the MK3-adaptor, | ||
- | ==== Asking questions ==== | + | All the other open-source projects are made only to read and document the use of the parts. |
- | Below each page, as well as below the blogposts, there is the option to ask us questions. Questions are generally answered by either Johannes Boonstra, a very experienced technical sales manager, or Matthijs Vader, the CEO, also technical. | + | i need such a sequence, which code i have to transfer to the MK3(FTDI), so i can set the parameter for charging current. |
- | So, which questions can be asked here? The short answer is that this is the place to ask questions that cannot be answered elsewhere. | + | my main program |
- | In more detail: | + | thanks for help |
- | * First, always read the manual(s), and make sure that your answer is not in there. | + | ===== Documentation ===== |
- | * For broken products, contact your dealer instead of contacting us on the blog. | + | |
- | * This is not the place to ask system design questions. For example "which mppt should I use with panels such and such", is a question that an end-user needs to ask his dealer or installer, and dealers and installers will be able to calculate it using the tools we provide online. Another example: "I want to design system such and such, what should I buy?", also contact a dealer or installer. They are trained and can far better help. | + | |
- | * Before asking a question on an existing installation, | + | |
- | If, with the above rules in mind, you do have a question to ask here, one last request: please do us a favour | + | ==== Looking for product documentation |
+ | Find your product | ||
+ | You can also search for your [[https:// | ||
+ | ==== Support ==== | ||
- | ==== Want to help improving documentation? | + | All support enquires should follow |
- | By creating an account at the top right, you can change this documentation yourself. Please don't hesitate to fix small typos yourself. But also bigger changes are much appreciated. We'll receive an email of every change, and can always revert back to a previous version. Read [[: | + | |
- | ==== Documents that still need to made available from main website ==== | + | Looking for Disqus? That has been replaced by Victron Community: https:// |
- | DC-Coupled PV | ||
- | Multi or Quattro combined with one or more solar chargers. | + | ==== Want to help improving documentation? |
- | + | By creating an account at the top right, you can change this documentation yourself. Please don't hesitate to fix small typos yourself. But also bigger changes are much appreciated. We'll receive an email of every change, and can always revert back to a previous version. Read [[:introduction|the introduction]] for some tips and tricks, for example how to receive email updates about new content if you want to stay up to date with changes. | |
- | * [[:ve.direct: | + | |
- | Other: | + | |
- | * [[battery_balancer_demo_webapp|Battery balancer demo webapp]] | + | |
- | * [[ac_current_sensor: | + | |
- | * [[:ve.can: | + | |
- | * [[eco_multi:start|EcoMulti installation manual]] | + | |
- | ==== DISQUS Comments ==== | + | |
