smart_battery_sense_manual [2019-01-22 10:16] 127.0.0.1 external edit |
smart_battery_sense_manual [2020-10-16 11:46] marmour |
- | Product page on our main website:\\ | + | |
- | https:// | + | |
- | === When can I use Smart Battery Sense ...and when should I avoid using it? === | + | |
- | * //Smart Battery Sense// is not needed, or allowed, in systems which are already controlled by a Color Control GX or Venus GX, see [[victronconnect: | + | |
- | * //Smart Battery Sense// is not needed for installations which already have a BMV-712 (battery monitor) with a temperature sensor accessory. | + | |
- | * For installations using a BMV-702 together with its optional temperature sensor accessory - for wireless connectivity consider adding a [[https:// | + | |
- | Connect the two eyelets to your battery terminals and attach the unit directly onto the battery-body using its self-adhesive strip. | + | |
- | For //banks// of batteries //Smart Battery Sense// may be connected to any one of the individual batteries. | + | |
- | If the bat+ and bat- cables are not long enough they may be extended - only make sure you use the same, or a thicker, gauge of cable. | + | |
- | This video will show you how to install //Smart Battery Sense// and includes step-by-step instructions for connecting it your mobile phone via VictronConnect [[victronconnect: | + | |
- | {{youtube> | + | |
- | //Smart Battery Sense// has two LEDs: a Bluetooth status LED (blue), and an Error LED (red). | + | |
- | On power-up, the Bluetooth LED will be slow-blinking - indicating that the device is ready to accept a Bluetooth connection. | + | |
- | If both LEDs remain illuminated, | + | |
- | When the LEDs are alternating quickly for more than 30 seconds, the //Smart Battery Sense// is in firmware update mode and will need to complete the update before it can be used. Firmware updates are performed (where necessary) after connecting to VictronConnect. | + | |
- | | Slow blinking | + | |
- | | Fast blinking | + | |
- | | On | Fast blinking | + | |
- | ===== 6. Troubleshooting ===== | + | |
- | === Operation and Dimensions === | + | |
- | ^ Description | + | |
- | | Dimension h x w x d (mm) | 14 x 38 x 38 | | + | |
- | | Cable length | + | |
- | | Eyelet hole size | 10mm (M10) | | + | |
- | | Fuse rating | + | |
- | | Operating temperature range | -10°C to +60°C | | + | |
- | | Operating voltage range | 8V to 60V | | + | |
- | | Absolute maximum voltage | + | |
- | === Power consumption === | + | |
- | ^ BatteryVoltage ^Not Connected ^Joining VE.Smart Network^Connected^ | + | |
- | | 12 V | 0.3 mA | 0.5 mA | + | |
- | | 24 V | 0.2 mA | 0.3 mA | + | |
- | | 48 V | 0.2 mA | 0.3 mA | + | |
