smart_battery_sense_manual
smart_battery_sense_manual [2018-03-05 13:07] – [5. LED Status codes] mkuiken | smart_battery_sense_manual [2018-11-30 11:52] – [5. LED Status codes] mkuiken | ||
Line 10: | Line 10: | ||
Simple to install & configure, //Smart Battery Sense// comes with an inline fuse and pre-crimped eyelets. Revealing the self-adhesive tape on the back allows you to mount it directly on the battery. | Simple to install & configure, //Smart Battery Sense// comes with an inline fuse and pre-crimped eyelets. Revealing the self-adhesive tape on the back allows you to mount it directly on the battery. | ||
+ | Product page on our main website:\\ | ||
+ | https:// | ||
=== When can I use Smart Battery Sense ...and when should I avoid using it? === | === When can I use Smart Battery Sense ...and when should I avoid using it? === | ||
Line 21: | Line 24: | ||
Connect the two eyelets to your battery terminals and attach the unit directly onto the battery-body using its self-adhesive strip. | Connect the two eyelets to your battery terminals and attach the unit directly onto the battery-body using its self-adhesive strip. | ||
- | For //banks// of batteries | + | For //banks// of batteries //Smart Battery Sense// may be connected to any one of the individual batteries. |
If the bat+ and bat- cables are not long enough they may be extended - only make sure you use the same, or a thicker, gauge of cable. | If the bat+ and bat- cables are not long enough they may be extended - only make sure you use the same, or a thicker, gauge of cable. | ||
Line 28: | Line 31: | ||
This video will show you how to install //Smart Battery Sense// and includes step-by-step instructions for connecting it your mobile phone via VictronConnect [[victronconnect: | This video will show you how to install //Smart Battery Sense// and includes step-by-step instructions for connecting it your mobile phone via VictronConnect [[victronconnect: | ||
- | {{youtube> | + | {{youtube> |
===== 5. LED Status codes ===== | ===== 5. LED Status codes ===== | ||
Line 47: | Line 50: | ||
- | | Fast blinking | + | |
===== 6. Troubleshooting ===== | ===== 6. Troubleshooting ===== | ||
Line 55: | Line 58: | ||
===== 7. Technical product specification ===== | ===== 7. Technical product specification ===== | ||
+ | === Operation and Dimensions === | ||
^ Description | ^ Description | ||
- | | Dimension h x w x d (mm) | 13 x 38 x 37 | | + | | Dimension h x w x d (mm) | 14 x 38 x 38 | |
| Cable length | | Cable length | ||
| Eyelet hole size | 10mm (M10) | | | Eyelet hole size | 10mm (M10) | | ||
Line 64: | Line 68: | ||
| Absolute maximum voltage | | Absolute maximum voltage | ||
+ | === Power consumption === | ||
+ | ^ BatteryVoltage ^Not Connected ^Joining VE.Smart Network^Connected^ | ||
+ | | 12 V | 0.3 mA | 0.5 mA | ||
+ | | 24 V | 0.2 mA | 0.3 mA | ||
+ | | 48 V | 0.2 mA | 0.3 mA | ||
~~DISQUS~~ | ~~DISQUS~~ |
