Both sides previous revision Previous revision Next revision | Previous revision Last revision Both sides next revision | ||
smart_battery_sense_manual [2018-03-05 11:00] mkuiken |
smart_battery_sense_manual [2020-09-25 09:51] mvader |
Line 11: | Line 11: | ||
Simple to install & configure, //Smart Battery Sense// comes with an inline fuse and pre-crimped eyelets. Revealing the self-adhesive tape on the back allows you to mount it directly on the battery. | Simple to install & configure, //Smart Battery Sense// comes with an inline fuse and pre-crimped eyelets. Revealing the self-adhesive tape on the back allows you to mount it directly on the battery. | ||
- | === System design & component selection | + | Product page on our main website: |
+ | https:// | ||
+ | === When can I use Smart Battery Sense ...and when should I avoid using it? === | ||
* Check the [[victronconnect: | * Check the [[victronconnect: | ||
- | * The Smart Battery Sense is not needed, | + | * //Smart Battery Sense// is not needed, |
- | * The Smart Battery Sense is not needed for installations | + | * //Smart Battery Sense// is not needed for installations |
- | * For installations | + | * For installations |
===== 2. Installation ===== | ===== 2. Installation ===== | ||
- | Connect the unit' | + | Connect the two eyelets to your battery terminals and attach |
- | For battery | + | For //banks// of batteries |
- | In case the supplied bat+ and bat- cables are not long enough, their length can be increased. Make sure to use the same, or thicker, gauge cable. | + | |
+ | If the bat+ and bat- cables are not long enough they may be extended - only make sure you use the same, or a thicker, gauge of cable. | ||
- | See this below video. Also, see the step by step procedure as documented in the [[victronconnect: | + | This video will show you how to install //Smart Battery Sense// and includes |
- | {{youtube> | + | {{youtube> |
===== 5. LED Status codes ===== | ===== 5. LED Status codes ===== | ||
- | The Smart Battery Sense has two LEDs, a Bluetooth status LED (blue), and an error LED (red). | + | //Smart Battery Sense// has two LEDs: a Bluetooth status LED (blue), and an Error LED (red). |
- | On power-up, the Bluetooth LED will be slow blinking indicating that the device is ready to accept a Bluetooth connection. | + | On power-up, the Bluetooth LED will be slow-blinking |
- | When both LEDs stay on, something is wrong with the Smart Battery Sense (hardware | + | If both LEDs remain illuminated, something is wrong with the //Smart Battery Sense// unit (Hardware |
- | When the LEDs are alternating quickly for more than 30 seconds, the Smart Battery Sense is in firmware update mode and needs to be updated | + | When the LEDs are alternating quickly for more than 30 seconds, the //Smart Battery Sense// is in firmware update mode and will need to complete the update |
^ Blue LED ^ Red LED ^ Smart Battery Sense state ^ Connection State ^ Remark | ^ Blue LED ^ Red LED ^ Smart Battery Sense state ^ Connection State ^ Remark | ||
- | | On | On | Not functional | + | | On | On | Not functional |
- | | Slow blinking | + | | Slow blinking |
- | | On | Off | Measuring V/T | Connected | + | | On | Off | Measuring V/T | Connected |
- | | Fast blinking | + | |
- | ===== 6. Trouble shooting | + | ===== 6. Troubleshooting |
See both the [[victronconnect: | See both the [[victronconnect: | ||
===== 7. Technical product specification ===== | ===== 7. Technical product specification ===== | ||
+ | === Operation and Dimensions === | ||
+ | ^ Description | ||
+ | | Dimension h x w x d (mm) | 14 x 38 x 38 | | ||
+ | | Cable length | ||
+ | | Eyelet hole size | 10mm (M10) | | ||
+ | | Fuse rating | ||
+ | | Operating temperature range | -10°C to +60°C | | ||
+ | | Operating voltage range | 8V to 60V | | ||
+ | | Absolute maximum voltage | ||
+ | | Bluetooth Frequency | ||
+ | | Bluetooth Power | -4dBm | | ||
+ | === Power consumption === | ||
+ | ^ BatteryVoltage ^Not Connected ^Joining VE.Smart Network^Connected^ | ||
+ | | 12 V | 0.3 mA | 0.5 mA | ||
+ | | 24 V | 0.2 mA | 0.3 mA | ||
+ | | 48 V | 0.2 mA | 0.3 mA | ||
