playground:playground
playground:playground [2015-10-16 11:25] – arnekaasplayground:playground [2024-02-09 08:30] (current) – created - external edit 127.0.0.1
-start with a smile every day: =) +====== PlayGround ======
-Then have a cup of tea: 8-) +
-creat a list: +
-  - 1234 +
-  - 5678 +
-  - 910 +
-**keep on playing...** +
-A new topic by Arne Kaas: "Creating a redundant and low-stand-by system" +
-Hi Mathijs and Johannes, +
-I've got some questions on how to make a 3 phase system redundant and more efficient by reducing stand-by power. +
-**Redundancy**: Can I install a 3 phase system with 6 quatro's/multies that will remain on, even if one of the six inverters will fail? Is it possible to connected 2 x a 3phase system with master and slave, where the slave will automatically become a master if the real master (3 fase system) fails?  +
-**Less standby power**:  +
-Looking at the standby power of a 3 fase system with 6 quatro's/multi's. It is possible to 'sleep' the second 3phase system at lower powers? +
-//With aux-relais and a power assistant I've already done this on Pampus, but this was complicated to setup and uses a lot op stand-by power. And if one of the six quatro's fail, I will still have a black-out. +
-Looking at the standby power of a 3 fase system with 3 quatro's/multi's. It is possible to 'sleep' 1 or 2 of three fase setup at lower powers or time windows? Like in the 'Nullust in Search modus (W)'?+
playground/playground.1444994744.txt.gz · Last modified: by arnekaas
