open_source:start
open_source:start [2016-09-27 06:51] – mvader | open_source:start [2023-06-01 06:40] (current) – [Q1. Why is the Bluetooth API not public?] guy_stewart | ||
Victron Energy has committed itself to make certain of its projects open source. On this page you'll find more information about available sources and projects. | Victron Energy has committed itself to make certain of its projects open source. On this page you'll find more information about available sources and projects. | ||
- | Also there is a list of other people' | + | Below some of our own projects, you'll also find a list of other people' |
Note that all this information is made available as is, for free, without any warranty and we do not commit to giving support. Although ofcourse we like to help out where possible. | Note that all this information is made available as is, for free, without any warranty and we do not commit to giving support. Although ofcourse we like to help out where possible. | ||
Line 9: | Line 9: | ||
Looking for Victron protocol documentation? | Looking for Victron protocol documentation? | ||
- | ===== Color Control GX, BBB, RaspberryPi & Venus ===== | + | Also, see our [[https:// |
- | While being a very successful | + | |
+ | ===== 1. Venus OS: the software on our GX product range and also for the Raspberry Pi===== | ||
+ | Venus OS is the Victron Energy Unix like distro with a linux kernel. It's the software that runs on our [[venus-os: | ||
+ | While being a very successful | ||
* Add drivers for certain products, if interesting enough we will add transmission and readout of that data on the [[https:// | * Add drivers for certain products, if interesting enough we will add transmission and readout of that data on the [[https:// | ||
* Add logic on the product, for example to control the relay, or do other things. | * Add logic on the product, for example to control the relay, or do other things. | ||
- | And we are currently working to make the software that runs on the CCGX, called Venus, run on the Beaglebone Black, a 45 USD single board computer similar to the RaspberryPi. Also someone from the community is working to make the full Venus image run on a RaspberryPi. Go through the developers mailing list archive to find the latest status. Communication to Victron Products can then be done using our standard USB interfaces, such as the VE.Direct USB cable. | ||
- | ==== Getting started ==== | + | Full information about Venus OS; and compatible hardware |
- | The CCGX runs Venus, our own unix like distribution with a Linux kernel. It contains the kernel | + | |
- | Venus is currently available in three ways: | ||
- | - Image for the CCGX | ||
- | - Image for the Beaglebone Black, aka BBB. Still a beta version, see venus-dev mailinglist for latest status. | ||
- | - Packages for Rasbian Wheezy, Rasbian Jessie and Debian Wheezy. | ||
- | Note that those packages are supplied on an as-is basis: no official support on those. Just best effort on the [[https:// | + | ==== 1.1 Dockerised Influx database & Grafana dashboard for Venus OS / GX Devices ===== |
- | In case you want to develop something, please share your thoughts with us. We want to help making it a success, and preferably also include it in our main repositories and images. | + | See https:// |
- | ==== More information | + | ===== 2. VRM Portal (https://vrm.victronenergy.com/) ===== |
- | * [[open_source: | + | |
- | * [[ccgx: | + | |
- | * developers mailing list: https://groups.google.com/forum/ | + | |
- | * [[https:// | + | |
- | For the die-hards: build your own CCGX image | + | While in itself not being an open source project, the VRM Portal database can be queried using the [[https://vrmapi.victronenergy.com/ |
- | * [[https://github.com/victronenergy/ | + | |
- | ===== VRM Portal (https:// | + | Also, you can interface to the GX product range using MQTT, see the [[https:// |
- | * [[vrm_portal: | + | |
- | ===== Other Victron related open source projects | + | ===== 3. Signal K ===== |
- | Many, many people all over the world are writing code to integrate Victron products | + | Signal K is a modern |
- | === Multis / Quattros / MK2 === | + | * Signal K Node Server plugin: [[https:// |
+ | * Raspberry Pi Venus image: [[https:// | ||
+ | * Signal K plugin for VE.Direct Serial to USB interface: [[https:// | ||
+ | * Blog - Sailing with Signal K: [[https:// | ||
+ | * Blog - Signal K: Embracing connectivity with Victron Energy: [[https:// | ||
+ | ===== 4. Other Victron related open source projects ===== | ||
+ | Many, many people all over the world are writing code to integrate Victron products and protocols into their systems. Below a list of public projects, aiming to help each other. | ||
+ | Tip: make sure to search for ' | ||
+ | Want to list your project here? Please go ahead and change this page yourself! See Login on upper right. | ||
+ | ==== 4.1 Multis / Quattros / MK2 ==== | ||
* https:// | * https:// | ||
Line 66: | Line 63: | ||
- | * [[http:// | ||
Line 74: | Line 69: | ||
- | * want to list your project here? Please go ahead and change this page yourself! | + | want to list your project here? Please go ahead and change this page yourself! |
- | === VE.Direct (MPPT Solar Chargers and BMV Battery Monitors) === | + | ==== 4.2 VE.Direct (MPPT Solar Chargers and BMV Battery Monitors) ==== |
- | * Use VE.Direct compatible Victron equipment with EMON (Open Energy Monitor) https:// | + | |
+ | Arduino: | ||
+ | * [[http:// | ||
+ | * https:// | ||
+ | * [[https:// | ||
+ | Battery/ | ||
+ | Other: | ||
+ | * Use VE.Direct compatible Victron equipment with EMON (Open Energy Monitor) https:// | ||
+ | * PvMonit : small real-time web interface and export to emonCMS for history (Brick from [[https:// | ||
+ | * https:// | ||
+ | * http:// | ||
+ | * https:// | ||
+ | * PvMonit now knows how to exploit the solar surplus when you are not using it with the "home automation" | ||
+ | * https:// | ||
+ | * https:// | ||
+ | * https:// | ||
* http:// | * http:// | ||
- | * want to list your project here? Please go ahead and change this page yourself! | + | * pgf's client/ |
+ | * Raspberry Pi / PHP Victron Data Logger (Text-Mode) Open Source: [[https:// | ||
+ | * SignalK: https:// | ||
+ | * victronPi: a Raspberry Pi driven graphical display of data from Victron equipment installed in a campervan [[http:// | ||
+ | * Victron Blog about the victronPi above: [[https:// | ||
+ | * velog: Serial log application for VE.Direct devices [[https:// | ||
+ | ===== Bluetooth Protocol ===== | ||
+ | * https:// | ||
~~DISQUS~~ | ~~DISQUS~~ |
open_source/start.1474951875.txt.gz · Last modified: 2016-09-27 06:51 by mvader
