open_source:ccgx:commandline
open_source:ccgx:commandline [2017-06-06 12:17] – [2.1 Checking current version] guystewart | open_source:ccgx:commandline [2021-03-06 14:38] – [8. Enabling VRM two-way communication (Remote VEConfigure aka vrmpubnub)] mvader | ||
- | This page explains how to change settings and/or update firmware for various Victron products which are connected to a Venus device, for example the Color Control GX. | + | This page explains how to change settings and/or update firmware for various Victron products which are connected to a [[venus-os: |
- | ==== 1.1 Use a normal tool instead of the command line ==== | + | For more software developer oriented command line tips & tricks, see [[https:// |
+ | ==== 1.1 No support warning | ||
- | Note that it is not at all necessary to use below command line instructions. We have far easier to use normal computer applications available: | + | Note regarding support: this document is made available for convenience only. There is no support on this type of using our products. Using the command line is outside normal use; |
+ | In case of questions, you can use the [[https:// | ||
+ | Our support staff on all official channels, Disqus and elsewhere, does not know how these tools can be used. | ||
+ | ==== 1.2 Use a normal tool instead of the command line ==== | ||
+ | It is not at all necessary to use below command line instructions. We have far easier to use normal computer applications available: | ||
=== VE.Bus products (Inverters, Multis, Quattros) === | === VE.Bus products (Inverters, Multis, Quattros) === | ||
Line 15: | Line 23: | ||
Line 31: | Line 39: | ||
- | ==== 1.2 Connecting to the command line and file transfer ==== | + | ==== 1.3 Connecting to the command line and file transfer ==== |
See the [[ccgx: | See the [[ccgx: | ||
Line 43: | Line 51: | ||
===== 2. Venus software updates ===== | ===== 2. Venus software updates ===== | ||
- | ==== 2.1 Checking current | + | Check firmware |
- | root@CCGX: | + | root@CCGX: |
v2.06 | v2.06 | ||
Color Control GX | Color Control GX | ||
Line 51: | Line 59: | ||
- | ==== 2.2 Updating Venus version | + | Then to update, this depends on which version |
- | To trigger an update check, run | + | See [[ccgx: |
+ | ==== 2.2 Venus v2.00 and later ==== | ||
+ | Checking for updates and triggering a new update is all done with / | ||
+ | For an introduction, | ||
+ | ==== 2.3 Venus v1.74 and before ==== | ||
+ | === Updating to v2.00 and later === | ||
+ | This needs to be done with an sdcard. There is no other way. See instructions here: | ||
+ | https:// | ||
+ | === Updating Venus version === | ||
+ | To trigger an update check, run: | ||
Line 59: | Line 84: | ||
- | If there are new updates found, and if the GUI is running and automatic updates are enabled, the GUI will automatically initiate an update followed by a reboot. Otherwise, trigger the installation yourself with | + | If there are new updates found, and if the GUI is running and automatic updates are enabled, the GUI will automatically initiate an update followed by a reboot. Otherwise, trigger the installation yourself with: |
Line 67: | Line 92: | ||
To change the Update-to setting, use set-feed.sh. | To change the Update-to setting, use set-feed.sh. | ||
- | ==== 2.3 Automatic | + | === Automatic |
To check if the device is configured to automatically update, query / | To check if the device is configured to automatically update, query / | ||
Line 108: | Line 133: | ||
- | Then transfer the new file back onto the Venus device. | + | Then transfer the new file back onto the [[venus-os: |
Line 119: | Line 144: | ||
Line 129: | Line 156: | ||
Updating other VE.Bus devices, such as the VE.Bus BMS and Digital Multi Control panels is not possible with vbdup. | Updating other VE.Bus devices, such as the VE.Bus BMS and Digital Multi Control panels is not possible with vbdup. | ||
- | Make sure that the Venus device (fe. CCGX), | + | Updating a MultiGrid and also a MultiPlus-II is not (yet) possible with vbdup. |
+ | Make sure that the [[venus-os: | ||
Line 241: | Line 270: | ||
- | vreg -n 0x10 -s 4 | + | vreg -n 0x24 -s 4 |
+ | ==== 4.3 Restarting a VE.Can device ==== | ||
+ | A bit of a trick: below code first sets them to bootloader mode, and then back out of it: | ||
+ | root@ccgx: | ||
+ | Querying devices | ||
+ | Found device, enabling UDF. | ||
+ | UDF is ready to accept update. | ||
+ | Udf enabled, update can begin. | ||
+ | root@ccgx: | ||
+ | Update end send | ||
+ | # vreg --help | ||
+ | -b,--bin | ||
+ | -g,--get | ||
+ | Get a register. | ||
+ | -n,--nad | ||
+ | -r,--run | ||
+ | Keep running. | ||
+ | -s,--set | ||
+ | COMMON OPTIONS: | ||
+ | -c, --canbus | ||
+ | -d, --dump | ||
+ | -h, --help | ||
+ | Print this help. | ||
+ | --log-before < | ||
+ | --log-after < | ||
+ | Like -log-before, | ||
+ | --silent | ||
+ | -v --verbose | ||
+ | Victron Energy B.V. | ||
+ | vreg -c socketcan: | ||
- | First make sure to stop the serial starter: | + | ==== 5.1 See connected devices ==== |
- | + | # svstat /service/* | grep vedirect | |
- | List all services running: | + | /service/vedirect-interface.ttyO2: |
- | svstat /service/* | + | ==== 5.2 Firmware update ==== |
- | Look for the product you and to update, and stop that service as well: | + | First stop the driver: |
- | | + | /opt/victronenergy/ |
Then update the product: | Then update the product: | ||
Line 281: | Line 404: | ||
- | and when done, start the service and the serial-starter | + | and when done, release |
- | svc -u /service/ | + | |
+ | See here: https:// | ||
Line 302: | Line 431: | ||
- If you want to set a password, go to Settings -> Remote Console -> Enable password check | - If you want to set a password, go to Settings -> Remote Console -> Enable password check | ||
- | ===== 8. Enabling VRM two-way communication (Remote VEConfigure aka vrmpubnub) ===== | ||
- | If you have a CCGX already installed, but VRM two-way communication is not enabled, follow these steps to enable it remotely: | ||
- | - SSH into CCGX (make a root password by following instructions [[ccgx: | ||
- | - VE.Configure should now be able to connect to the CCGX | ||
