multiplus_faq
multiplus_faq [2022-09-20 02:24] – [Software Settings] guystewart | multiplus_faq [2022-10-31 11:51] – mvader | ||
Line 109: | Line 109: | ||
Loss of mains detection will push and pull at voltage and frequency to see if there is still a generating source. This process can cause issues with some generators, or high impedance connections to generators. | Loss of mains detection will push and pull at voltage and frequency to see if there is still a generating source. This process can cause issues with some generators, or high impedance connections to generators. | ||
Line 250: | Line 252: | ||
