multiplus_faq
multiplus_faq [2020-01-08 10:35] – [Still not connecting?] guy_stewart | multiplus_faq [2022-10-31 11:51] – mvader | ||
Line 52: | Line 52: | ||
Line 109: | Line 109: | ||
Loss of mains detection will push and pull at voltage and frequency to see if there is still a generating source. This process can cause issues with some generators, or high impedance connections to generators. | Loss of mains detection will push and pull at voltage and frequency to see if there is still a generating source. This process can cause issues with some generators, or high impedance connections to generators. | ||
Line 181: | Line 183: | ||
- | Effectively, | + | Effectively, when Weak AC is enabled, the total charge current possible will be less that the rated maximum charge current output of the charger (under normal conditions). |
Line 241: | Line 243: | ||
[[https:// | [[https:// | ||
