multiplus_faq
multiplus_faq [2019-12-17 13:15] – guy_stewart | multiplus_faq [2022-05-30 12:24] – guystewart | ||
Line 52: | Line 52: | ||
Line 181: | Line 181: | ||
- | Effectively, | + | Effectively, when Weak AC is enabled, the total charge current possible will be less that the rated maximum charge current output of the charger (under normal conditions). |
Line 200: | Line 200: | ||
====== Still not connecting? ====== | ====== Still not connecting? ====== | ||
- | If the unit is still not connecting, | + | If the unit is still not connecting, |
+ | Switch | ||
Try with a different generator. | Try with a different generator. | ||
Line 231: | Line 241: | ||
[[https:// | [[https:// | ||
~~DISQUS~~ | ~~DISQUS~~ |
