multiplus_faq
multiplus_faq [2019-12-17 13:15] – guy_stewart | multiplus_faq [2020-01-08 10:35] – [Still not connecting?] guy_stewart | ||
Line 200: | Line 200: | ||
====== Still not connecting? ====== | ====== Still not connecting? ====== | ||
- | If the unit is still not connecting, | + | If the unit is still not connecting, |
+ | Switch | ||
Try with a different generator. | Try with a different generator. |
