multiplus_faq
multiplus_faq [2019-12-01 23:50] – updated ve-configure to veconfigure guy_stewart | multiplus_faq [2022-09-25 22:04] – [1.5 Loss of mains detection (LOM)] clarification on grid codes boekel | ||
Line 10: | Line 10: | ||
Line 35: | Line 35: | ||
If your generator is smaller than the recommended size for your inverter/ | If your generator is smaller than the recommended size for your inverter/ | ||
Line 45: | Line 52: | ||
Line 102: | Line 109: | ||
Loss of mains detection will push and pull at voltage and frequency to see if there is still a generating source. This process can cause issues with some generators, or high impedance connections to generators. | Loss of mains detection will push and pull at voltage and frequency to see if there is still a generating source. This process can cause issues with some generators, or high impedance connections to generators. | ||
Line 174: | Line 183: | ||
- | Effectively, | + | Effectively, when Weak AC is enabled, the total charge current possible will be less that the rated maximum charge current output of the charger (under normal conditions). |
Line 193: | Line 202: | ||
====== Still not connecting? ====== | ====== Still not connecting? ====== | ||
- | If the unit is still not connecting, | + | If the unit is still not connecting, |
+ | Switch | ||
Try with a different generator. | Try with a different generator. | ||
Line 213: | Line 232: | ||
[[https:// | [[https:// | ||
Line 222: | Line 243: | ||
~~DISQUS~~ | ~~DISQUS~~ |
