multiplus_faq
multiplus_faq [2019-12-01 23:50] – updated ve-configure to veconfigure guy_stewart | multiplus_faq [2020-06-23 06:05] – [Software Changes] mvader | ||
Line 10: | Line 10: | ||
Line 35: | Line 35: | ||
If your generator is smaller than the recommended size for your inverter/ | If your generator is smaller than the recommended size for your inverter/ | ||
Line 45: | Line 52: | ||
Line 193: | Line 200: | ||
====== Still not connecting? ====== | ====== Still not connecting? ====== | ||
- | If the unit is still not connecting, | + | If the unit is still not connecting, |
+ | Switch | ||
Try with a different generator. | Try with a different generator. | ||
Line 213: | Line 230: | ||
[[https:// | [[https:// | ||
