multiplus_faq
multiplus_faq [2019-10-17 13:48] – [3.1 Derating of the power factor] guystewart | multiplus_faq [2020-10-06 02:15] – [3.1 Derating of the power factor] guy_stewart | ||
Line 10: | Line 10: | ||
Line 35: | Line 35: | ||
If your generator is smaller than the recommended size for your inverter/ | If your generator is smaller than the recommended size for your inverter/ | ||
Line 45: | Line 52: | ||
Line 59: | Line 66: | ||
Line 126: | Line 133: | ||
- | ====== 2. In the “General” tab of VE-Configure: ====== | + | ====== 2. In the “General” tab of VEConfigure: ====== |
Line 141: | Line 148: | ||
Line 162: | Line 169: | ||
Line 174: | Line 181: | ||
- | Effectively, | + | Effectively, when Weak AC is enabled, the total charge current possible will be less that the rated maximum charge current output of the charger (under normal conditions). |
- | ====== 4. In the “Inverter” tab of VE-Configure: ====== | + | ====== 4. In the “Inverter” tab of VEConfigure: ====== |
===== 4.1 PowerAssist ===== | ===== 4.1 PowerAssist ===== | ||
Line 193: | Line 200: | ||
====== Still not connecting? ====== | ====== Still not connecting? ====== | ||
- | If the unit is still not connecting, | + | If the unit is still not connecting, |
+ | Switch | ||
Try with a different generator. | Try with a different generator. | ||
- | There can be issues with generators with Residual Current Devices (RCD' | + | As troubleshooting and correcting these faults have serious safety implications, |
If there is still no connection, contact your dealer or distributor. Tell them the steps that you have taken already to attempt to get it to work and they can help from there. | If there is still no connection, contact your dealer or distributor. Tell them the steps that you have taken already to attempt to get it to work and they can help from there. | ||
Line 210: | Line 230: | ||
[[https:// | [[https:// | ||
