multiplus_faq
multiplus_faq [2019-06-11 07:03] – guy_stewart | multiplus_faq [2019-12-01 23:50] – updated ve-configure to veconfigure guy_stewart | ||
Line 59: | Line 59: | ||
Line 103: | Line 103: | ||
===== 1.5 Loss of mains detection (LOM) ===== | ===== 1.5 Loss of mains detection (LOM) ===== | ||
+ | **Disabling LOM** | ||
- | + | ====== 2. In the “General” tab of VEConfigure: ====== | |
- | ====== 2. In the “General” tab of VE-Configure: ====== | + | |
Line 132: | Line 141: | ||
Line 153: | Line 162: | ||
Line 164: | Line 173: | ||
+ | Effectively, | ||
- | ====== 4. In the “Inverter” tab of VE-Configure: ====== | + | ====== 4. In the “Inverter” tab of VEConfigure: ====== |
===== 4.1 PowerAssist ===== | ===== 4.1 PowerAssist ===== | ||
Line 186: | Line 197: | ||
Try with a different generator. | Try with a different generator. | ||
- | There can be issues with generators with Residual Current Devices (RCD' | + | As troubleshooting and correcting these faults have serious safety implications, |
If there is still no connection, contact your dealer or distributor. Tell them the steps that you have taken already to attempt to get it to work and they can help from there. | If there is still no connection, contact your dealer or distributor. Tell them the steps that you have taken already to attempt to get it to work and they can help from there. |
