multiplus_faq
multiplus_faq [2019-01-22 10:16] – external edit 127.0.0.1 | multiplus_faq [2019-10-17 13:48] – [3.1 Derating of the power factor] guystewart | ||
Line 82: | Line 82: | ||
Line 96: | Line 103: | ||
===== 1.5 Loss of mains detection (LOM) ===== | ===== 1.5 Loss of mains detection (LOM) ===== | ||
+ | **Disabling LOM** | ||
Line 150: | Line 166: | ||
Line 157: | Line 173: | ||
+ | Effectively, | ||
Line 162: | Line 180: | ||
+ | The [[https:// | ||
Line 177: | Line 216: | ||
[[https:// | [[https:// | ||
Line 183: | Line 224: | ||
