multiplus_faq
multiplus_faq [2018-12-17 21:39] – [Generator Sizing] guy_stewart | multiplus_faq [2023-02-16 01:50] (current) – guy_stewart | ||
Line 10: | Line 10: | ||
Line 26: | Line 26: | ||
It is possible to overload generators with the power demanded by the Multi' | It is possible to overload generators with the power demanded by the Multi' | ||
- | ^ Inverter/Charger Size ^ Recommended Generator Size ^ 240V AC Input Current Limit ^ | + | ^ Inverter Charger Size ^ Minimum |
| 800VA | 2 kVa | 5A | | | 800VA | 2 kVa | 5A | | ||
| 1200VA | 2.5 kVa | 7A | | | 1200VA | 2.5 kVa | 7A | | ||
Line 35: | Line 35: | ||
If your generator is smaller than the recommended size for your inverter/ | If your generator is smaller than the recommended size for your inverter/ | ||
Line 45: | Line 52: | ||
Line 59: | Line 66: | ||
Line 82: | Line 89: | ||
Line 95: | Line 109: | ||
- | For Full information | + | This part is only applicable |
- | ==== What is LOM detection? ==== | + | Loss of mains detection |
- | LOM is an automatic process that detects a change | + | For large and stable Generators Type B LOM will work, and is safer. |
+ | However, if you are experiencing issues with voltage, | ||
- | ==== Why is LOM detection required? ==== | + | **Disabling |
- | The purpose of LOM is to detect that the Multi is no longer | + | Disabling the LOM on an input connected |
+ | Disabling the LOM on an input connected to generator can be done, but then other methods / warning signs / physical lockout safety measures must be provided. Ensuring | ||
- | ==== How does LOM detection | + | For Full information on Loss of Mains detection, |
- | To detect a loss of mains, the inverter/ | + | |
- | When connected to a generator, with a long extension cable or long ‘last mile’ cable, the pushing and pulling on the grid does create high currents, and as a result the inverter/ | + | |
- | ==== LOM detection | + | |
- | LOM detection comes in two flavours: **Type A** and **Type B**. | + | |
- | **Type A** is the strongest form LOM detection, which results in the quickest detection time. It requires a low impedance connection to the grid (short, well sized cables). LOM **Type A** will not work with generators. | + | |
- | **Type B** has a more soft approach. Resulting in a slightly longer detection time. Still acceptable in several countries (South-Africa, | + | |
- | For generators on which also **Type B** does not work, see Disabling LOM. | + | |
- | ==== Disabling LOM ==== | + | |
- | Besides choosing Type A and B, it is also possible to disable the LOM entirely. | + | |
- | Note disabling the LOM on an input connected to the grid is only allowed when other external safety equipment is installed. | + | |
- | Disabling the LOM on an input connected to generator can be done, but then other methods / warning signs must be provided. Ensuring that any installer that will work on the generator will make sure to also switch off or otherwise disconnect the Inverter/ | + | |
- | {{ : | + | **Example configuration in VEConfigure** |
- | ===== Example configuration in VEConfigure | + | |
- | ===== Questions ===== | ||
- | ==== Q1: Where can I get the password? ==== | ||
- | A: From your dealer. | + | ====== 2. In the “General” tab of VEConfigure: ====== |
- | ==== Q2: Can I use ESS in a vehicle or a boat? ==== | + | |
- | A: No you cannot. After unplugging the shore cord it can take up to a few seconds for the system to detect the loss of mains and open the back-feed relay. During those seconds, the shore power plug will be `live`: there is 230 Volts AC on the terminals. The exact number of seconds differs per country and depends on the local requirements. | + | |
- | The same applies to other solution where the wiring is not protected against accidental removing, for example a simple cable with end-user removable plug, such as a portable power supply. | + | |
- | ==== Q3: Can I use ESS with a generator? ==== | + | |
- | A: Yes you can. Note that the only installation type where that makes sense is a land based installation (no boat, and no vehicle). A Quattro must be used with AC input 1 connected to the generator, and AC input 2 connected to the grid. The role of the generator will be to provide power during a long grid failure. | + | |
- | Some, bigger or better quality generators, will be able to work with LOM **Type B**. For other less stable generators it will be required to disable LOM entirely. In that case make the installation such that it is still safe: no simple extensions cords, use enclosed wiring cabinets with warnings on the outside and/or an external ENS. | + | |
- | ==== Q4: I use ESS, but have disabled feed-back, is a grid-code still required? ==== | + | |
- | A: Yes, also in this case LOM is required to make for a safe and also local regulations compliant system. Running ESS with disabled-feed-back is still not the same as using a Multi in its default configuration without ESS. | + | |
- | ====== 2. In the “General” tab of VE-Configure: ====== | + | |
Line 177: | Line 150: | ||
Line 198: | Line 171: | ||
Line 209: | Line 182: | ||
+ | Effectively, | ||
+ | The [[https:// | ||
+ | https:// | ||
Line 223: | Line 243: | ||
[[https:// | [[https:// | ||
Line 228: | Line 250: | ||
- | ===== Disqus ===== | ||
