multiplus_faq
multiplus_faq [2018-01-15 02:52] – [3. Example configuration in VEConfigure] guystewart | multiplus_faq [2019-10-17 13:48] – [3.1 Derating of the power factor] guystewart | ||
Line 2: | Line 2: | ||
- | What to do when a MultiPlus, or Quattro, does not accept generator power | + | __What |
- | ---- | + | __ |
Line 17: | Line 18: | ||
- | **Generator Sizing** | ||
- | It is possible to overload generators with the power demanded by the Multi' | ||
- | 2 kVa - 800VA Multi | + | ==== Generator Sizing ==== |
- | 2.5 kVa - 1200VA | + | It is possible to overload generators with the power demanded by the Multi's charger. The following generator sizings are indicative of those sizes are appropriate for the charging potential of the various multis. It is still possible to overload these generator sizings with large loads, and flat batteries using the PowerAssist function, so they should be treated as safe minimums to eliminate this as a potential cause of issues. A bigger generator is usually better. |
- | 3 kVa - 1600VA | + | ^ Inverter Charger Size ^ Minimum Recommended Generator Size ^ 240V AC Input Current Limit ^ |
+ | | 1600VA | ||
- | 5 kVa - 3000VA Multi | + | If your generator is smaller than the recommended size for your inverter/ |
- | 8 kVa - 5000VA Multi | + | ==== Operation ==== |
- | **Operation** | ||
Line 41: | Line 45: | ||
Line 77: | Line 82: | ||
Line 92: | Line 104: | ||
===== 1.5 Loss of mains detection (LOM) ===== | ===== 1.5 Loss of mains detection (LOM) ===== | ||
- | For Full information on Loss of Mains detection, please | + | Loss of mains detection |
- | ==== What is LOM detection? ==== | + | For large and stable Generators Type B LOM will work, and is safer. |
- | LOM is an automatic process that detects a change and loss of the generator/ | + | **Disabling |
- | ==== Why is LOM detection required? ==== | + | Disabling the LOM on an input connected to the grid is only allowed when other external safety equipment |
- | The purpose | + | For Full information on Loss of Mains detection, please see [[ve.bus:grid-codes-and-loss-of-mains-detection|this more detailed explanation.]] |
- | ==== How does LOM detection relate to overload shutdowns? ==== | ||
- | To detect a loss of mains, the inverter/ | + | **Example configuration in VEConfigure** |
- | When connected to a generator, with a long extension cable or long ‘last mile’ cable, the pushing and pulling on the grid does create high currents, and as a result the inverter/ | + | |
- | ==== LOM detection Type A and Type B ==== | + | |
- | LOM detection comes in two flavours: | + | |
- | **Type A** is the strongest form LOM detection, which results in the quickest detection time. It requires a low impedance connection to the grid (short, well sized cables). LOM **Type A** will not work with generators. | + | |
- | **Type B** has a more soft approach. Resulting in a slightly longer detection time. Still acceptable in several countries (South-Africa, | + | |
- | For generators on which also **Type B** does not work, see Disabling LOM. | + | |
- | ==== Disabling LOM ==== | + | |
- | Besides choosing Type A and B, it is also possible to disable the LOM entirely. | + | |
- | Note disabling the LOM on an input connected to the grid is only allowed when other external safety equipment is installed. | + | |
- | Disabling the LOM on an input connected to generator can be done, but then other methods / warning signs must be provided. Ensuring that any installer that will work on the generator will make sure to also switch off or otherwise disconnect the Inverter/ | + | |
- | ===== Example configuration in VEConfigure | + | |
- | ===== Questions ===== | + | |
- | ==== Q1: Where can I get the password? ==== | + | |
- | A: From your dealer. | ||
- | ==== Q2: Can I use ESS in a vehicle or a boat? ==== | ||
- | A: No you cannot. After unplugging the shore cord it can take up to a few seconds for the system to detect the loss of mains and open the back-feed relay. During those seconds, the shore power plug will be `live`: there is 230 Volts AC on the terminals. The exact number of seconds differs per country and depends on the local requirements. | ||
- | The same applies to other solution where the wiring is not protected against accidental removing, for example a simple cable with end-user removable plug, such as a portable power supply. | ||
- | ==== Q3: Can I use ESS with a generator? ==== | ||
- | A: Yes you can. Note that the only installation type where that makes sense is a land based installation (no boat, and no vehicle). A Quattro must be used with AC input 1 connected to the generator, and AC input 2 connected to the grid. The role of the generator will be to provide power during a long grid failure. | ||
- | Some, bigger or better quality generators, will be able to work with LOM **Type B**. For other less stable generators it will be required to disable LOM entirely. In that case make the installation such that it is still safe: no simple extensions cords, use enclosed wiring cabinets with warnings on the outside and/or an external ENS. | ||
- | ==== Q4: I use ESS, but have disabled feed-back, is a grid-code still required? ==== | ||
- | A: Yes, also in this case LOM is required to make for a safe and also local regulations compliant system. Running ESS with disabled-feed-back is still not the same as using a Multi in its default configuration without ESS. | ||
Line 197: | Line 166: | ||
Line 204: | Line 173: | ||
+ | Effectively, | ||
Line 209: | Line 180: | ||
- | ===== Disqus | + | |
+ | The [[https:// | ||
+ | ===== DISQUS | ||
~~DISQUS~~ | ~~DISQUS~~ |
