multiplus_faq
multiplus_faq [2017-10-01 01:49] – [2.2 AC Input Current Limit] guystewart | multiplus_faq [2019-10-17 13:48] – [3.1 Derating of the power factor] guystewart | ||
Line 2: | Line 2: | ||
- | ---- | + | __ |
Line 17: | Line 18: | ||
- | **Generator Sizing** | ||
- | 5 kVa - 3000VA Multi | + | ==== Operation ==== |
- | 8 kVa - 5000VA Multi | ||
- | **Operation** | ||
Line 41: | Line 45: | ||
Line 77: | Line 82: | ||
Line 86: | Line 100: | ||
+ | **Disabling LOM** | ||
+ | **Example configuration in VEConfigure** | ||
Line 107: | Line 144: | ||
a 5kVA generator typically provides about 4 kW | a 5kVA generator typically provides about 4 kW | ||
80% of 4 kW is 3200 W | 80% of 4 kW is 3200 W | ||
3200 W / 230 V volts = 13.9 A | 3200 W / 230 V volts = 13.9 A | ||
Set the AC Current Input Limit to 13 A | Set the AC Current Input Limit to 13 A | ||
Line 125: | Line 166: | ||
+ | Effectively, | ||
Line 135: | Line 181: | ||
- | ===== Disqus | + | ====== 4. In the “Inverter” tab of VE-Configure: |
+ | The [[https:// | ||
+ | ===== DISQUS | ||
~~DISQUS~~ | ~~DISQUS~~ |
