multiplus_faq
multiplus_faq [2017-06-27 04:49] – guystewart | multiplus_faq [2022-10-31 11:51] – mvader | ||
Line 2: | Line 2: | ||
- | ---- | + | __ |
- | Some generators are more suitable than others for use with inverter/ | + | |
+ | Some generators are more suitable than others for use with inverter/ | ||
Line 15: | Line 16: | ||
AVR equipped generators will audibly struggle and eventually stall when overloaded, signalling there is an issue. They are also better able to cope with a brief high current load which would overload an inverter based generator. | AVR equipped generators will audibly struggle and eventually stall when overloaded, signalling there is an issue. They are also better able to cope with a brief high current load which would overload an inverter based generator. | ||
- | Inverter based generators have a characteristic where the motor continues to run even if the unit has electronically overloaded and no longer delivering power. It may appear that the generator is operating and the system is charging when it isn't. These units are also more easily overloaded by surge loads. | + | Inverter based generators have a characteristic where the motor continues to run even if the unit has electronically overloaded and no longer delivering power. It may appear that the generator is operating and the system is charging when it isn't. These units are also more easily overloaded by surge loads, as they are electronically limited rather than mechanically. |
+ | ==== Generator Sizing ==== | ||
+ | It is possible to overload generators with the power demanded by the Multi' | ||
+ | ^ Inverter Charger Size ^ Minimum Recommended Generator Size ^ 240V AC Input Current Limit ^ | ||
+ | If your generator is smaller than the recommended size for your inverter/ | ||
+ | ==== Operation ==== | ||
- | **Operation** | ||
Line 27: | Line 52: | ||
- | **Software | + | ==== Software |
Line 40: | Line 66: | ||
- | ====== 1. In the “Grid” tab of VE-Configure: ====== | + | For information on VEConfigure and how to get started, please see this [[https:// |
+ | ====== 1. In the “Grid” tab of VEConfigure: ====== | ||
Line 61: | Line 89: | ||
Line 72: | Line 109: | ||
+ | ===== 1.5 Loss of mains detection (LOM) (Only applicable to ESS systems) ===== | ||
- | ====== 2. In the “General” tab of VE-Configure: ====== | + | This part is only applicable on systems where a grid-code is selected (generally only ESS systems) on an off-grid system a grid code should not be used and in the selection box for grid code, ' |
+ | **Disabling LOM** | ||
+ | **Example configuration in VEConfigure** | ||
+ | ====== 2. In the “General” tab of VEConfigure: ====== | ||
- | ===== 2.1 Load impact limitation ===== | ||
- | **Dynamic current limiter** : (default = disabled) | + | ===== 2.1 Dynamic current limiter |
+ | (default = disabled) | ||
This feature is intended to reduce load impacts on low-power generators, such as portable inverter technology models. These generators may be unable to respond to sudden load impacts. | This feature is intended to reduce load impacts on low-power generators, such as portable inverter technology models. These generators may be unable to respond to sudden load impacts. | ||
Line 85: | Line 148: | ||
By activating the limiter, the **PowerAssist®** function of the MultiPlus will absorb the change in load and transfer it smoothly to the generator, giving it time to react. | By activating the limiter, the **PowerAssist®** function of the MultiPlus will absorb the change in load and transfer it smoothly to the generator, giving it time to react. | ||
- | ====== 3. In the " | + | ===== 2.2 AC Input Current Limit ===== |
+ | The charger on the Multiplus is very powerful. If you have an existing generator that is not able to supply the maximum charging current of the Multi, you will need to adjust the AC Input Current Limit in the General Tab of VEConfigure. | ||
+ | A reasonable starting point for the AC Current input limit is 80% of the generator capacity in Watts. For example: | ||
+ | a 5kVA generator typically provides about 4 kW | ||
+ | 80% of 4 kW is 3200 W | ||
+ | 3200 W / 230 V volts = 13.9 A | ||
+ | Set the AC Current Input Limit to 13 A | ||
+ | If you find the generator is still overloading, | ||
+ | There is another additional setting in the Charger Tab for DC current limiting. | ||
+ | The AC input current should be adjusted first, as it also takes into account the PowerAssist functionality. | ||
+ | The Multi is able to synchronise the generator waveform with it's own and provide power to the loads from the generator as well charging the battery. This means it still possible to overload the generator with a low 'DC Charger current limit' if the AC input limit is not also set correctly to the size of the generators output. | ||
+ | ====== 3. In the " | ||
+ | Effectively, | ||
+ | The [[https:// | ||
