multiplus_faq
multiplus_faq [2017-06-27 04:49] – guystewart | multiplus_faq [2019-06-11 07:03] – guy_stewart | ||
Line 2: | Line 2: | ||
- | ---- | + | __ |
Line 15: | Line 16: | ||
AVR equipped generators will audibly struggle and eventually stall when overloaded, signalling there is an issue. They are also better able to cope with a brief high current load which would overload an inverter based generator. | AVR equipped generators will audibly struggle and eventually stall when overloaded, signalling there is an issue. They are also better able to cope with a brief high current load which would overload an inverter based generator. | ||
- | Inverter based generators have a characteristic where the motor continues to run even if the unit has electronically overloaded and no longer delivering power. It may appear that the generator is operating and the system is charging when it isn't. These units are also more easily overloaded by surge loads. | + | Inverter based generators have a characteristic where the motor continues to run even if the unit has electronically overloaded and no longer delivering power. It may appear that the generator is operating and the system is charging when it isn't. These units are also more easily overloaded by surge loads, as they are electronically limited rather than mechanically. |
+ | ==== Generator Sizing ==== | ||
+ | It is possible to overload generators with the power demanded by the Multi' | ||
+ | ^ Inverter Charger Size ^ Minimum Recommended Generator Size ^ 240V AC Input Current Limit ^ | ||
+ | If your generator is smaller than the recommended size for your inverter/ | ||
+ | ==== Operation ==== | ||
- | **Operation** | ||
Line 27: | Line 45: | ||
Line 39: | Line 58: | ||
+ | For information on VE-Configure and how to get started, please see this [[https:// | ||
====== 1. In the “Grid” tab of VE-Configure: | ====== 1. In the “Grid” tab of VE-Configure: | ||
Line 61: | Line 82: | ||
Line 69: | Line 99: | ||
+ | ===== Example configuration in VEConfigure ===== | ||
Line 77: | Line 121: | ||
- | ===== 2.1 Load impact limitation ===== | ||
- | **Dynamic current limiter** : (default = disabled) | + | ===== 2.1 Dynamic current limiter |
+ | (default = disabled) | ||
This feature is intended to reduce load impacts on low-power generators, such as portable inverter technology models. These generators may be unable to respond to sudden load impacts. | This feature is intended to reduce load impacts on low-power generators, such as portable inverter technology models. These generators may be unable to respond to sudden load impacts. | ||
By activating the limiter, the **PowerAssist®** function of the MultiPlus will absorb the change in load and transfer it smoothly to the generator, giving it time to react. | By activating the limiter, the **PowerAssist®** function of the MultiPlus will absorb the change in load and transfer it smoothly to the generator, giving it time to react. | ||
+ | ===== 2.2 AC Input Current Limit ===== | ||
+ | The charger on the Multiplus is very powerful. If you have an existing generator that is not able to supply the maximum charging current of the Multi, you will need to adjust the AC Input Current Limit in the General Tab of VE-Configure. | ||
+ | A reasonable starting point for the AC Current input limit is 80% of the generator capacity in Watts. For example: | ||
+ | a 5kVA generator typically provides about 4 kW | ||
+ | 80% of 4 kW is 3200 W | ||
+ | 3200 W / 230 V volts = 13.9 A | ||
+ | Set the AC Current Input Limit to 13 A | ||
+ | If you find the generator is still overloading, | ||
+ | There is another additional setting in the Charger Tab for DC current limiting. | ||
+ | The AC input current should be adjusted first, as it also takes into account the PowerAssist functionality. | ||
+ | The Multi is able to synchronise the generator waveform with it's own and provide power to the loads from the generator as well charging the battery. This means it still possible to overload the generator with a low 'DC Charger current limit' if the AC input limit is not also set correctly to the size of the generators output. | ||
====== 3. In the " | ====== 3. In the " | ||
Line 89: | Line 157: | ||
+ | The [[https:// | ||
+ | ~~DISQUS~~ |
