mppt-error-codes
mppt-error-codes [2019-12-11 23:22] – [Err 2 - Battery voltage too high] mvader | mppt-error-codes [2024-02-12 05:48] (current) – [Err 54 - Inverter output voltage] guy_stewart | ||
+ | * Remote | ||
Line 27: | Line 40: | ||
Line 33: | Line 58: | ||
+ | Possible solutions | ||
Line 53: | Line 85: | ||
The feature of this safety protection is to detect a shorted cell; and stop charging. | The feature of this safety protection is to detect a shorted cell; and stop charging. | ||
==== Err 28 - Power stage issue ==== | ==== Err 28 - Power stage issue ==== | ||
Line 72: | Line 130: | ||
Note that this error was introduced in v1.36. So when doing an update, it might look like the firmware update caused this issue; but it doesn' | Note that this error was introduced in v1.36. So when doing an update, it might look like the firmware update caused this issue; but it doesn' | ||
+ | Possible causes: | ||
Line 77: | Line 143: | ||
- | * Error 39: The charger will automatically resume operation once the battery voltage drops below the float level for 1 minute. | + | * Error 39: The charger will automatically resume operation once the battery voltage drops below its maximum voltage setting (normally Equalisation or Absorption voltages). It can also takes a minute |
Line 101: | Line 240: | ||
+ | __Background__ | ||
- | The charger detects multiple conflicting network sources trying | + | The inverters remain operational, |
- | Applies to SmartSolar MPPTs and SmartSolar MPPTs VE.Can. | + | ==== Err 73 - Multiple AC inputs ==== |
- | The typical reason for the error to show is that the charger | + | Per phase only one active connection |
- | Resolution: disable the parallel operation by connecting VictronConnect, going to settings, then "VE.Smart networking" | + | The inverters remain operational, they won't connect |
- | For SmartSolar MPPT VE.Can only, also make sure its not connected | + | ==== Err 74 - Phase overload ==== |
+ | Applies | ||
- | Once the conflict is resolved | + | The number of inverters in parallel doesn' |
Line 145: | Line 330: | ||
Line 154: | Line 350: | ||
- | ~~DISQUS~~ | + | |
mppt-error-codes.1576102953.txt.gz · Last modified: 2019-12-11 23:22 by mvader
