mppt-error-codes
mppt-error-codes [2019-07-12 16:44] – [Err 68 - Network misconfigured] mvader | mppt-error-codes [2019-11-30 10:10] – [Err 119 - Settings data lost] boekel | ||
Line 68: | Line 68: | ||
Disconnect all wires, and then reconnect all wires. If the error persists the charge controller is probably faulty. | Disconnect all wires, and then reconnect all wires. If the error persists the charge controller is probably faulty. | ||
Line 146: | Line 148: | ||
- wait 3 minutes, and power up again. | - wait 3 minutes, and power up again. |
