mppt-error-codes
mppt-error-codes [2019-07-12 16:44] – [Err 68 - Network misconfigured] mvader | mppt-error-codes [2019-11-08 14:43] – tabreu | ||
Line 68: | Line 68: | ||
Disconnect all wires, and then reconnect all wires. If the error persists the charge controller is probably faulty. | Disconnect all wires, and then reconnect all wires. If the error persists the charge controller is probably faulty. | ||
==== Err 33 - PV over-voltage ==== | ==== Err 33 - PV over-voltage ==== |
