mppt-error-codes
mppt-error-codes [2017-04-16 12:47] – [Err 67 - No BMS] mvader | mppt-error-codes [2019-05-06 13:58] – [Err 68 - Network misconfigured] mvader | ||
+ | Detailed error codes can be read with a remote panel, such as the Color Control GX or the MPPT Control. | ||
Line 7: | Line 10: | ||
+ | This error can also occur if the battery voltage is set to a lower voltage than the actual battery voltage. | ||
Line 30: | Line 33: | ||
- | Disconnect | + | If the error does not auto-reset disconnect |
- | If the error persists the charge controller is probably faulty. | + | A cause for this error can be switching on a very large load on the battery side. |
Line 45: | Line 48: | ||
+ | Disconnect all wires, and then reconnect all wires. Also, make sure the minus on the MPPT charge controller (PV minus/ | ||
Line 59: | Line 71: | ||
The current from the solar-panel array has exceeded 75A. This error could be generated due to an internal system fault. | The current from the solar-panel array has exceeded 75A. This error could be generated due to an internal system fault. | ||
- | ==== Err 38 - Input shutdown | + | ==== Err 38, Err 39 - PV Input shutdown ==== |
- | To protect the battery from over-charging the panel input is shut down. To recover from this condition first disconnect the solar panels and disconnect the battery. Wait for 3 minutes reconnect the battery first and next the panels. If the error persists the charge controller is probably faulty. | + | To protect the battery from over-charging the panel input is shorted. |
+ | Error recovery: | ||
+ | * Error 38: First disconnect the solar panels and disconnect the battery. Wait for 3 minutes, then reconnect the battery first and next the panels. | ||
Line 88: | Line 111: | ||
Note that (solar-)chargers automatically configure themselves to be BMS-controlled when they are connected to one; either direct or via a Color Control GX or Venus GX. | Note that (solar-)chargers automatically configure themselves to be BMS-controlled when they are connected to one; either direct or via a Color Control GX or Venus GX. | ||
- | ==== Err 114 - CPU temperature | + | ==== Err 68 - Network misconfigured ==== |
+ | The charger detects multiple conflicting network sources trying to take control of the charger. | ||
+ | Applies to SmartSolar MPPTs and SmartSolar MPPTs VE.Can. | ||
+ | The typical reason for the error to show is that the charger is configured to operate in parallel using our [[https:// | ||
+ | Resolution: disable the parallel operation by connecting VictronConnect, | ||
+ | For SmartSolar MPPT VE.Can only, also make sure its not connected to a [[https:// | ||
+ | Once the conflict is resolved the error will disappear and the charger will resume normal operation, usually within a minute. | ||
Line 94: | Line 133: | ||
Line 104: | Line 146: | ||
