hv_battery_compatibility:start
hv_battery_compatibility:start [2026-06-22 06:43] – guy_stewarthv_battery_compatibility:start [2026-10-10 08:20] (current) – guy_stewart
Line 3: Line 3:
 The Victron HS19 high voltage inverter/charger only works with supported and compatible high voltage batteries.  The Victron HS19 high voltage inverter/charger only works with supported and compatible high voltage batteries.
-{{:hv_battery_compatibility:usr_victronenergy2_media_6a595cd1bde8b63d89c1b97683f54c6f_multi_hs19_solar_-_drawings_for_datasheet.png|}}+{{:hv_battery_compatibility:2026-06-22_hv_battery_diagram.png|}}
 These batteries are strongly recommended to be connected via “BMS-Can” (CANBus) to a GX device. The HS19 supports direct battery connection without a GX device, see product manual further details.  These batteries are strongly recommended to be connected via “BMS-Can” (CANBus) to a GX device. The HS19 supports direct battery connection without a GX device, see product manual further details.
Line 9: Line 9:
 Victron provides the following support documentation to assist qualified system designers and installers to select suitable batteries for their application.  Victron provides the following support documentation to assist qualified system designers and installers to select suitable batteries for their application.
-Batteries compatible with the Victron HS19.
-Click the brand name for the brand-specific setup guide and manufacturer links. This information should always be verified with the battery manufacturer. +
 +Click the brand name for brand-specific information and manufacturer links. This information should always be verified with the battery manufacturer.
 +==== Batteries compatible with the Victron HS19 ====
 ^ Brand ^ Model / series ^ Usable voltage range with HS19 (V DC) ^ Modules per stack ^ Capacity (kWh)  ^  ^ Brand ^ Model / series ^ Usable voltage range with HS19 (V DC) ^ Modules per stack ^ Capacity (kWh)  ^
Line 19: Line 21:
 | [[hv_battery_compatibility:lbsa|LBSA]] | HV range (Rhino IntelliFlex HV) | 660 - 927 | 10 - 11 | 80 - 88 |  | [[hv_battery_compatibility:lbsa|LBSA]] | HV range (Rhino IntelliFlex HV) | 660 - 927 | 10 - 11 | 80 - 88 |
 | [[hv_battery_compatibility:mg|MG]] | RS series (RS 230) | 672 - 876 | 14 - 15 | 165 - 177 |  | [[hv_battery_compatibility:mg|MG]] | RS series (RS 230) | 672 - 876 | 14 - 15 | 165 - 177 |
 +| [[hv_battery_compatibility:pylontech|Pylontech]] | Force-H3 | 650 - 920 | 7 - 8 | 36 - 41 |
 +| [[hv_battery_compatibility:pytes|Pytes]] | HV48100 | 665 - 870 | 14 - 15 | 72 - 77 |
 +| [[hv_battery_compatibility:pytes|Pytes]] | HV48300 Max | 672 - 979 | 15 - 17 | 241 - 273 |
 | [[hv_battery_compatibility:zyc|ZYC]] | SIMPO Pro E | 673 - 958 | 11 | 127 |  | [[hv_battery_compatibility:zyc|ZYC]] | SIMPO Pro E | 673 - 958 | 11 | 127 |
 | [[hv_battery_compatibility:zyc|ZYC]] | SIMPO Pro S | 650 - 934 | 16 | 82 |  | [[hv_battery_compatibility:zyc|ZYC]] | SIMPO Pro S | 650 - 934 | 16 | 82 |
hv_battery_compatibility/start.1782110617.txt.gz · Last modified: by guy_stewart
