hv_battery_compatibility:pytes
hv_battery_compatibility:pytes [2026-06-12 12:42] – created guy_stewarthv_battery_compatibility:pytes [2026-09-18 03:13] (current) – guy_stewart
-====== Pytes ====== +====== Pytes HV batteries ======
-FIXME Not yet tested.+
 ===== Manufacturer links ===== ===== Manufacturer links =====
   * Homepage: [[https://www.pytesess.com/|Pytes ESS]]   * Homepage: [[https://www.pytesess.com/|Pytes ESS]]
-  * HV range: [[https://www.pytesess.com/High-Voltage-Battery/HV48100.html|Pytes HV Series (HV48100)]] +  * Product page: [[https://www.pytesess.com/High-Voltage-Battery/HV48100.html|HV48100]]
-  * Current HV line: HV Series (HV48100, HV48300, HV48100 SE); 51.2 V / 5.12 kWh BMU modules in series under HV48100 BCU controller, working range 200 - 870 V+  * Datasheet: not publicly linked; see the [[https://www.pytesess.com/Catalogue/|Pytes download centre]]
 +This page covers HV48100 and HV48300 Max.
 +Pytes also offers HV48100 SE and HV48300 Max SE. The calculations below do not apply to the SE models.
 +===== Use with the HS19 (650 - 1000 V DC) =====
 +These calculations check voltage limits only. They do not establish compatibility.
 +They keep the full stated battery voltage range within the HS19 and battery controller limits.
 +**HV48100**
 +  * Modules per stack: **14 or 15** are within the product range.
 +  * Voltage range: **665 - 870 V DC**
 +  * Nominal Capacity per stack: **71.68 - 76.8 kWh**.
 +**HV48300 Max**
 +  * Modules per stack: **15 - 17**.
 +  * Voltage range across these configurations: **672 - 979.2 V DC**.
 +  * Capacity per stack: **241.14 - 273.29 kWh**.
 +  * A stack with 14 modules can fall to 627.2 V. A stack with 18 modules can reach 1036.8 V.
 +Each stack has its own voltage range. The combined range above is not the range of each stack.
 +===== Product specifications =====
 +**HV48100**
 +  * Battery module (BMU): 51.2 V nominal, 5.12 kWh, 45.5 - 58 V.
 +  * Battery controller (BCU): 200 - 870 V working range; 5 - 15 BMUs.
-===== Compatibility status =====+**HV48300 Max**
 +  * Battery module (BMU): 51.2 V nominal, 16.076 kWh, 44.8 - 57.6 V.
 +  * Battery controller (BCU): 224 - 1497 V working range; 5 - 26 BMUs.
-  * Test status: TBD
-  * FDCan support: TBD
 ===== Setup guide ===== ===== Setup guide =====
-FIXME To be written once a model is tested.+Contact battery manufacturer for setup instructions.
hv_battery_compatibility/pytes.1781268176.txt.gz · Last modified: by guy_stewart
