hv_battery_compatibility:pylontech
Pylontech HV batteries
Force-H3
Use with the HS19 (650 - 1000 V DC)
  • Modules per stack: 7 or 8 (the Pylontech product documentation allows 2 - 7; 6 or fewer sits below the HS19 voltage range, Pylontech permits either 7 or 8 to be used with Victron HS19)
  • Usable voltage range: 650 - 920 V. A 7 module stack discharge floor is 649 V (estimated at 2.9 V/cell).
  • Capacity: 36 kWh per 7 module stack or 41 kWh per 8 modules stack.
Product specifications
  • Module FH10050: 102.4 V nominal, 50 Ah / 5.12 kWh (32S LFP)
  • Up to 6 stacks in parallel
hv_battery_compatibility/pylontech.txt · Last modified: by guy_stewart
