hv_battery_compatibility:pylontech
Pylontech HV batteries
Force-H3
Manufacturer links
- Product page: Pylontech Force-H3
- Datasheet: Force-H3 datasheet (Pylontech)
- Operation manual: Force-H3 operation manual
Use with the HS19 (650 - 1000 V DC)
- Modules per stack: 7 or 8 (the Pylontech product documentation allows 2 - 7; 6 or fewer sits below the HS19 voltage range, Pylontech permits either 7 or 8 to be used with Victron HS19)
- Usable voltage range: 650 - 920 V. A 7 module stack discharge floor is 649 V (estimated at 2.9 V/cell).
- Capacity: 36 kWh per stack
Product specifications
- Module FH10050: 102.4 V nominal, 50 Ah / 5.12 kWh (32S LFP)
- Up to 6 stacks in parallel
hv_battery_compatibility/pylontech.1782213904.txt.gz · Last modified: by guy_stewart
Add this page to your book
Manage book (
Help
