hv_battery_compatibility:pylontech
Pylontech HV batteries
Force-H3
Use with the HS19 (650 - 1000 V DC)
  • Modules per stack: 7 only (the product allows 2 - 7; 6 or fewer sits below the HS19 range)
  • Usable voltage range: 650 - 818 V. The battery's own discharge floor is approx. 605 V (estimated at 2.7 V/cell), below the HS19 minimum, so the bottom of the SOC range is not available.
  • Capacity: 36 kWh per stack
Product specifications
  • Module FH10050: 102.4 V nominal, 50 Ah / 5.12 kWh (32S LFP)
  • Up to 6 stacks in parallel
hv_battery_compatibility/pylontech.1782204165.txt.gz · Last modified: by guy_stewart
