hv_battery_compatibility:pylontech
Pylontech HV batteries
Force-H3
Manufacturer links
- Product page: Pylontech Force-H3
- Datasheet: Force-H3 datasheet (Pylontech)
- Operation manual: Force-H3 operation manual
Use with the HS19 (650 - 1000 V DC)
- Modules per stack: 7 only (the product allows 2 - 7; 6 or fewer sits below the HS19 range)
- Usable voltage range: 650 - 818 V. The battery's own discharge floor is approx. 605 V (estimated at 2.7 V/cell), below the HS19 minimum, so the bottom of the SOC range is unusable.
- Capacity: 36 kWh per stack
Full product specifications (unverified, from manufacturer documents)
- Module FH10050: 102.4 V nominal, 50 Ah / 5.12 kWh (32S LFP)
- Up to 6 stacks in parallel
Compatibility status
- Test status: will be tested soon
- FDCan support: only up to 500 kbit/s (status 04-2024, update requested)
Powercube H2 (deprecated)
Not for use with the HS19
Maximum stack voltage is 648 V at 12 modules, below the HS19 minimum of 650 V. No valid configuration exists. Not compatible with current HS19 hardware.
hv_battery_compatibility/pylontech.1781267616.txt.gz · Last modified: by guy_stewart
Add this page to your book
Manage book (
Help
