hv_battery_compatibility:hubble
Hubble HV100
Manufacturer links
- Product page: Hubble High Voltage 100Ah Stack (1C)
- Datasheet: HV100 datasheet V1.3
Use with the HS19 (650 - 1000 V DC)
- Modules per stack: 8 only (the product allows 3 - 8; 7 or fewer sits below the HS19 range)
- Usable voltage range: 717 - 891 V
- Capacity: 82 kWh per stack
Product specifications
- Module: 102.4 V nominal (32S LiFePO4), 100 Ah / 10.24 kWh
- 100 A continuous charge/discharge (1C); up to 8 stacks per string with comms
Compatibility status
- Test status: tested and running in field tests
Setup guide
Contact battery manufacturer for setup instructions.
hv_battery_compatibility/hubble.1781683303.txt.gz · Last modified: by guy_stewart
Add this page to your book
Manage book (
Help
