hv_battery_compatibility:hubble
hv_battery_compatibility:hubble [2026-06-12 12:34] – created guy_stewarthv_battery_compatibility:hubble [2026-06-22 07:35] (current) – [Compatibility status] guy_stewart
Line 11: Line 11:
   * Usable voltage range: **717 - 891 V**   * Usable voltage range: **717 - 891 V**
   * Capacity: **82 kWh** per stack   * Capacity: **82 kWh** per stack
-  * FIXME derived from datasheet per-module voltages, not yet verified
-===== Full product specifications (unverified, from manufacturer datasheet) =====+===== Product specifications =====
   * Module: 102.4 V nominal (32S LiFePO4), 100 Ah / 10.24 kWh   * Module: 102.4 V nominal (32S LiFePO4), 100 Ah / 10.24 kWh
   * 100 A continuous charge/discharge (1C); up to 8 stacks per string with comms   * 100 A continuous charge/discharge (1C); up to 8 stacks per string with comms
-===== Compatibility status =====
-  * Test status: tested and running in field tests
-  * FDCan support: update requested
 ===== Setup guide ===== ===== Setup guide =====
-FIXME Setup instructions to be written.+Contact battery manufacturer for setup instructions.
hv_battery_compatibility/hubble.1781267695.txt.gz · Last modified: by guy_stewart
