hv_battery_compatibility:cegasa
Cegasa E/Scal 6
Manufacturer links
- Product page: Cegasa E/Scal 6
- Datasheet: TDS E/Scal 6 (English, Nov 2025)
Use with the HS19 (650 - 1000 V DC)
- Modules per stack: 13 - 15 (the product allows 3 - 15, but fewer than 13 modules sits below the HS19 input range)
- Usable voltage range: 676 - 940 V
- Capacity: 75 - 86 kWh per stack
Full product specifications (unverified, from manufacturer datasheet)
- Module: 57.6 V nominal, 5.76 kWh (~100 Ah)
- Up to 4 strings in parallel (max 60 modules, 345 kWh)
- Recommended current 50 A, max 63 A continuous, 100 A peak (<1 min)
- Note: E/Scal 6 is the renamed continuation of the E/Scal HV; certificates may still reference the old name
Compatibility status
- Test status: tested and running in field tests
Setup guide
Contact battery manufacturer for setup instructions.
hv_battery_compatibility/cegasa.1781682783.txt.gz · Last modified: by guy_stewart
Add this page to your book
Manage book (
Help
