hv_batteries:cegasa
Cegasa E/Scal 6
Use with the HS19 (650 - 1000 V DC)
  • Modules per stack: 13 - 15 (the product allows 3 - 15, but fewer than 13 modules sits below the HS19 input range)
  • Usable voltage range: 676 - 940 V
  • Capacity: 75 - 86 kWh per stack
  • FIXME derived from datasheet per-module voltages, not yet verified
Full product specifications (unverified, from manufacturer datasheet)
  • Module: 57.6 V nominal, 5.76 kWh (~100 Ah)
  • Up to 4 strings in parallel (max 60 modules, 345 kWh)
  • Recommended current 50 A, max 63 A continuous, 100 A peak (<1 min)
  • Note: E/Scal 6 is the renamed continuation of the E/Scal HV; certificates may still reference the old name
Compatibility status
  • Test status: tested and running in field tests
  • FDCan support: yes, but needs verification
Setup guide
FIXME Setup instructions to be written.
hv_batteries/cegasa.1781267011.txt.gz · Last modified: by guy_stewart
