evchargingstation
evchargingstation [2020-08-02 07:22] – lucian | evchargingstation [2020-08-26 08:18] – [Specifications:] lucian | ||
====== EV Charging Station ====== | ====== EV Charging Station ====== | ||
+ | ===== Description: | ||
+ | High Power AC charger -22KW | ||
+ | The maximum power the EV Charging Station can deliver is 22KW in 3phase mode or 7.3kW per phase. It also can be used in single phase installations | ||
+ | Wi-Fi: 802.11 b/g/n for configuration and monitoring | ||
+ | For the initial setup but also for monitoring, the internal Wi-Fi module can be configured in Access Point mode or Station mode | ||
+ | Touch Screen | ||
+ | 4.3-inch touch screen for monitoring and control | ||
+ | Light Ring | ||
+ | Fully programmable Light Ring around charging port, to fast determine the state of the device. It can be programed on the web interface to display different light effects base on the current state (disconnected, | ||
+ | Automatic mode | ||
+ | To ensure maximum PV system efficiency, the EV Charging station has an Automatic mode that detects when excess power is available, and use only that power to charge the vehicle | ||
+ | Manual mode | ||
+ | Configurable output current 6-32A | ||
+ | Real-time data display options | ||
+ | - Color Control GX or other GX devices: | ||
+ | see the Venus documents on our website. | ||
+ | - On the webpage of the device | ||
+ | - On the VRM portal | ||
===== Installation: | ===== Installation: | ||
The device must be installed on a flat surface, recommended not in the in direct sunlight, so the screen can be read. | The device must be installed on a flat surface, recommended not in the in direct sunlight, so the screen can be read. | ||
- | To ensure maximum power will be delivered to the vehicle, cable cross-section must be 5x6mm2. There is not internal RCD, so an external one, closer to the Charging Station, must be installed. | + | To ensure maximum power will be delivered to the vehicle, cable cross-section must be 5x6mm2. There is no internal RCD, so an external one, closer to the Charging Station, must be installed. For this kind of applications, |
+ | current of not greater than 30mA is recommended. | ||
Start by opening the back cover. In the bottom left corner, there is a connector for powering the device. If it will be used on a single phase configuration, | Start by opening the back cover. In the bottom left corner, there is a connector for powering the device. If it will be used on a single phase configuration, | ||
Line 25: | Line 63: | ||
This mode is used to charge the EV, only using the excess power. In the "Auto ON Grid" menu, the parameters for this mode can be configured. 2 values are important for controlling this mode - the power exported to the grid and the power discharged from the battery. When those 2 are configured, the device will use all the excess power, so the exported power is as close to 0 as possible. | This mode is used to charge the EV, only using the excess power. In the "Auto ON Grid" menu, the parameters for this mode can be configured. 2 values are important for controlling this mode - the power exported to the grid and the power discharged from the battery. When those 2 are configured, the device will use all the excess power, so the exported power is as close to 0 as possible. | ||
+ | ===== Specifications: | ||
+ | * Unordered List ItemEv Charging Station 22kW | ||
+ | * Input voltage range (V AC) 170-265 | ||
+ | * Rated charge current 32A/ | ||
+ | * Nominal power 22kW | ||
+ | * Max. PV short circuit current | ||
+ | * Wi-Fi standards 802.11 b/g/n | ||
+ | * Self-consumption 15mA@230V | ||
+ | * Configurable Max. Current 10-32A | ||
+ | * Configurable price/kWh (Eur) Default setting: 0.13 (adjustable) | ||
+ | * Control type Touch Screen, Web page, GX Device over ModbusTCP | ||
+ | * Light Ring 55 light configurable light effects available | ||
+ | * Protection External RCD is required | ||
+ | * Operating temperature -30 to +50°C | ||
+ | * Humidity 95%, | ||
+ | * Data communication ModbusTCP over WIFI | ||
+ | * ENCLOSURE Colour Blue (RAL 5012) | ||
+ | * Power terminals 10 mm² / AWG7 | ||
+ | * Protection category IP43 (electronic components)??? | ||
+ | * Weight 3 kg | ||
+ | * Dimensions (h x w x d) 390 x 300 x 150 mm | ||
+ | * STANDARDS Safety IEC 61851-1, IEC 61851-22 ??? | ||
+ | * Equipped with detection for Relay Contact welded and missing protective conductor | ||
