evchargingstation
evchargingstation [2020-08-02 06:22] – lucian | evchargingstation [2020-08-02 07:22] – lucian | ||
====== EV Charging Station ====== | ====== EV Charging Station ====== | ||
+ | ===== Installation: | ||
+ | The device must be installed on a flat surface, recommended not in the in direct sunlight, so the screen can be read. | ||
+ | To ensure maximum power will be delivered to the vehicle, cable cross-section must be 5x6mm2. There is not internal RCD, so an external one, closer to the Charging Station, must be installed. | ||
+ | Start by opening the back cover. In the bottom left corner, there is a connector for powering the device. If it will be used on a single phase configuration, | ||
+ | When the Ev Charging Station is powered up, it will start in access point mode. On the screen, the SSID name and password are visible, also the IP address of the device. You can either use that information to connect to it, or by scanning the QR Code displayed on the screen, it should ask if you want to automatically connect. | ||
+ | After a successful connection, in your browser, put the IP address of the device - default one is **192.168.0.1**, | ||
+ | Go to Setting/ | ||
+ | If used in a configuration with a GX device, to be able to charge using the excess power, the EV Charging Station must be configured to communicate with that GX device. In the ModbusTcp menu, enable "Use Modbus TCP Integration" | ||
+ | Now on the main web page you should see the system information and the current flowing in this system | ||
+ | There are 2 working modes - Manual and Automatic. | ||
+ | ==== Manual Mode ==== | ||
+ | In this mode, we can control the charging power by using the slider on the LCD screen or the web page. We can start or stop the charging process by pressing the " | ||
+ | ==== Auto Mode ==== | ||
+ | This mode is used to charge the EV, only using the excess power. In the "Auto ON Grid" menu, the parameters for this mode can be configured. 2 values are important for controlling this mode - the power exported to the grid and the power discharged from the battery. When those 2 are configured, the device will use all the excess power, so the exported power is as close to 0 as possible. | ||
