evchargingstation
evchargingstation [2020-08-26 08:18] – [Specifications:] lucian | evchargingstation [2021-02-25 07:48] – [Specifications:] guystewart | ||
Line 2: | Line 2: | ||
====== EV Charging Station ====== | ====== EV Charging Station ====== | ||
+ | ==== NOTE: DRAFT MANUAL. PRODUCT NOT AVAILABLE AND ALSO THERE IS NO ETA ==== | ||
Line 10: | Line 10: | ||
===== Description: | ===== Description: | ||
- | High Power AC charger | + | High Power AC Charger |
- | The maximum power the EV Charging Station can deliver is 22KW in 3phase mode or 7.3kW per phase. It also can be used in single phase installations | + | The maximum power the EV Charging Station can deliver is 22 kW in 3phase mode or 7.3 kW per phase. It also can be used in single phase installations. |
Wi-Fi: 802.11 b/g/n for configuration and monitoring | Wi-Fi: 802.11 b/g/n for configuration and monitoring | ||
- | For the initial setup but also for monitoring, the internal Wi-Fi module can be configured in Access Point mode or Station mode | + | For the initial setup but also for monitoring, the internal Wi-Fi module can be configured in Access Point mode or Station mode. |
Touch Screen | Touch Screen | ||
- | 4.3-inch touch screen for monitoring and control | + | 4.3-inch touch screen for monitoring and control. |
Light Ring | Light Ring | ||
- | Fully programmable Light Ring around charging port, to fast determine the state of the device. It can be programed | + | Fully programmable Light Ring around charging port, to fast determine the state of the device. It can be programmed |
Automatic mode | Automatic mode | ||
Line 53: | Line 53: | ||
Go to Setting/ | Go to Setting/ | ||
- | If used in a configuration with a GX device, to be able to charge using the excess power, the EV Charging Station must be configured to communicate with that GX device. In the ModbusTcp menu, enable "Use Modbus TCP Integration" | + | If used in a configuration with a GX device, to be able to charge using the excess power, the EV Charging Station must be configured to communicate with that GX device. In the ModbusTcp menu, enable "Use Modbus TCP Integration" |
Now on the main web page you should see the system information and the current flowing in this system | Now on the main web page you should see the system information and the current flowing in this system | ||
Line 65: | Line 65: | ||
===== Specifications: | ===== Specifications: | ||
- | * Unordered List ItemEv | + | * Ev Charging Station 22kW |
* Input voltage range (V AC) 170-265 | * Input voltage range (V AC) 170-265 | ||
* Rated charge current 32A/ | * Rated charge current 32A/ |
