ess:scheduled_charging
ess:scheduled_charging [2018-10-31 12:37] – [Scheduled Charging Manual] iburger | ess:scheduled_charging [2018-11-11 10:38] – guy_stewart | ||
- | ====== Scheduled Charging ====== | + | This page has been moved into [[https://www.victronenergy.com/live/ess:design-installation-manual# |
- | //Scheduled Charging// is a feature meant for use with Time Of Use (TOU) electricity tariffs. It allows charging the batteries during off-peak hours, usually to offset energy use during peak hours. It also allows charging to stop at a preset SOC to allow room for PV charging later in the day. | + | |
- | ===== 2. Configuration ==== | + | |
- | Scheduled charging is available as part of ESS, under Settings | + | |
- | At present, five schedules can be set. To make it easier to see at a glance what is configured, a summary of the start day, time and duration is shown for each. | + | |
- | For each schedule you can select | + | |
- | During charging, | + | |
- | ===== 3. Stop charge on SOC ===== | + | |
- | ===== 4. Frequently asked questions ===== | + | |
- | ==== Why does the Multi not discharge the battery after charging ends? ==== | + | |
- | ==== How can I prevent discharge to reserve battery capacity for later in the day? ==== | + | |
- | ==== What happens if I set overlapping schedules? ==== | + | |
- | The first matching schedule takes priority. If the two schedules have different SOC limits, the limit of the second matching scheduled charge window takes effect after the first scheduled charge window ends. | + |
ess/scheduled_charging.txt · Last modified: 2019-08-15 12:50 by guy_stewart
