ess:quick-installation-guide
ess:quick-installation-guide [2018-12-06 14:05] guy_stewartess:quick-installation-guide [2019-08-15 12:34] – replace venus-device with GX device guy_stewart
Line 45: Line 45:
   * Victron inverter/charger(s): [[https://www.victronenergy.com/inverters-chargers]]   * Victron inverter/charger(s): [[https://www.victronenergy.com/inverters-chargers]]
   * Victron Interface MK3-USB: [[https://www.victronenergy.com/accessories/interface-mk3-usb]]   * Victron Interface MK3-USB: [[https://www.victronenergy.com/accessories/interface-mk3-usb]]
-  * A Victron [[venus-os:start|Venus-device]] such as the CCGX or Venus GX: [[https://www.victronenergy.com/panel-systems-remote-monitoring]]+  * A Victron [[venus-os:start|GX device]] such as the CCGX or Venus GX: [[https://www.victronenergy.com/live/venus-os:start]]
   * RJ45 UTP cable(s): [[https://www.victronenergy.com/cables/rj45-utp-cable]]   * RJ45 UTP cable(s): [[https://www.victronenergy.com/cables/rj45-utp-cable]]
   * Batteries   * Batteries
Line 72: Line 72:
 To equip the system with WiFi you will need: To equip the system with WiFi you will need:
   * Victron WiFi module: BPP900100200  or BPP900200200   * Victron WiFi module: BPP900100200  or BPP900200200
-  *  Details on connecting your [[venus-os:start|Venus-device]] to the internet are in the [[ccgx:start#internet_connectivity|CCGX manual, chapter Internet]]+  *  Details on connecting your [[venus-os:start|GX device]] to the internet are in the [[ccgx:start#internet_connectivity|CCGX manual, chapter Internet]]
 In case of a smart battery such as BYD, you might need: In case of a smart battery such as BYD, you might need:
Line 78: Line 78:
 ===== Step 4 - Install all equipment ===== ===== Step 4 - Install all equipment =====
Line 152: Line 151:
-===== Step 9 - Make the Venus-device settings =====+===== Step 9 - Make the GX device settings =====
   * Go to ESS settings on CCGX, make ESS settings   * Go to ESS settings on CCGX, make ESS settings
Line 160: Line 159:
   * Find Energy meter(s) on CCGX, assign correct role   * Find Energy meter(s) on CCGX, assign correct role
-For details, see the [[ess:design-installation-manual#venus-device_-_ess_settings|relevant section in the ESS Design and installation manual]].+For details, see the [[ess:design-installation-manual#GX device_-_ess_settings|relevant section in the ESS Design and installation manual]].
Line 178: Line 177:
   * Consider limiting access to end-user   * Consider limiting access to end-user
   * Consider turning automatic firmware updates off   * Consider turning automatic firmware updates off
ess/quick-installation-guide.txt · Last modified: 2023-05-23 10:45 by guy_stewart
