ess:quick-installation-guide
ess:quick-installation-guide [2018-11-22 16:22] – [Step 2 - Decide what type of ESS] mleeftink | ess:quick-installation-guide [2019-09-24 02:07] – [Step 5 - Update firmware of all equipment] mleeftink | ||
Line 27: | Line 27: | ||
* Essential loads are used | * Essential loads are used | ||
- | To get an idea of all possibilities | + | See below drawings to get an idea of all possibilities. |
- | These two drawings show ESS systems using a multiPlus-II or a MultiPlus or Quattro | + | |
- | {{: | + | Both drawings show all AC- and DC-Coupled combinations. |
- | {{:ess:ess_with_multi.png?400|}} | + | {{:ess:ess_with_multiplus-ii.png? |
===== Step 3 - Select the system hardware ===== | ===== Step 3 - Select the system hardware ===== | ||
Line 42: | Line 44: | ||
* Victron inverter/ | * Victron inverter/ | ||
* Victron Interface MK3-USB: [[https:// | * Victron Interface MK3-USB: [[https:// | ||
- | * A Victron | + | * A Victron |
* RJ45 UTP cable(s): [[https:// | * RJ45 UTP cable(s): [[https:// | ||
* Batteries | * Batteries | ||
Line 59: | Line 61: | ||
And one or more of the Energy Meter accessories: | And one or more of the Energy Meter accessories: | ||
- | * Victron ASS030572018 - RS485 to USB interface 1.8m | + | * Victron ASS030572018 - RS485 to USB interface 1.8m: [[https:// |
* Victron Zigbee to USB and RS485 converter: [[https:// | * Victron Zigbee to USB and RS485 converter: [[https:// | ||
- | To measure PV from a PV Inverter | + | To measure PV power coming |
* Victron Current sensor: [[https:// | * Victron Current sensor: [[https:// | ||
* Victron Energy meters: [[https:// | * Victron Energy meters: [[https:// | ||
- | * Details on how to measure PV Inverter | + | * Details on how to measure |
To equip the system with WiFi you will need: | To equip the system with WiFi you will need: | ||
* Victron WiFi module: BPP900100200 | * Victron WiFi module: BPP900100200 | ||
- | * Details on connecting your Venus-device to the internet are in the [[ccgx: | + | * Details on connecting your [[venus-os: |
In case of a smart battery such as BYD, you might need: | In case of a smart battery such as BYD, you might need: | ||
Line 75: | Line 77: | ||
===== Step 4 - Install all equipment ===== | ===== Step 4 - Install all equipment ===== | ||
Line 92: | Line 93: | ||
The easiest way is to let the CCGX or Venus GX do an automatic update. This can be selected from its menu, once it is connected to the internet. Alternatively update via a SD card. For instructions how to update see: [[ccgx: | The easiest way is to let the CCGX or Venus GX do an automatic update. This can be selected from its menu, once it is connected to the internet. Alternatively update via a SD card. For instructions how to update see: [[ccgx: | ||
- | === MPPTs Solar Chargers === | + | === Inverter/ |
Use VictronConnect; | Use VictronConnect; | ||
- | === Multi and Quattro Inverter/ | ||
- | {{youtube> | ||
- | For details, see the [[updating_firmware: | ||
Line 149: | Line 145: | ||
- | ===== Step 9 - Make the Venus-device settings ===== | + | ===== Step 9 - Make the GX device settings ===== |
* Go to ESS settings on CCGX, make ESS settings | * Go to ESS settings on CCGX, make ESS settings | ||
Line 157: | Line 153: | ||
* Find Energy meter(s) on CCGX, assign correct role | * Find Energy meter(s) on CCGX, assign correct role | ||
- | For details, see the [[ess: | + | For details, see the [[ess: |
Line 175: | Line 171: | ||
* Consider limiting access to end-user | * Consider limiting access to end-user | ||
* Consider turning automatic firmware updates off | * Consider turning automatic firmware updates off | ||
ess/quick-installation-guide.txt · Last modified: 2023-05-23 10:45 by guy_stewart
